Super Regulator
That's what I thought, too! Figure 1, in instructions is misleading.
This is the correct way to connect with a pre-regulator. The ground is on outside of J1 and J5. correct?
Now how to troubleshoot?
I am measuring
19.8v on positive reg.
-9.18v on negative reg
When turning on:
positive reg LED turns on shortly and goes off.
negative reg LED stays on.
Target output is +/-17v
I've made the conscious decision to include protection against reverse polarity input, on all of the PCBs whose Gerber CAD files I give away here on diyAudio. I figure it's cheap insurance and the loss of headroom is tiny when you make D1 a Schottky type.
D2 might be gilding the lily a little. It's a 2nd safety net in case two bad things happen simultaneously: (a) the user connects the input voltage backwards; (b) D1's reverse leakage current is enormous. Then D2 clamps the negative voltage on |Vcc| to something less than a silicon diode drop.
  • sb140.pdf
    sb140.pdf
  • bat41.pdf
    bat41.pdf
A good point. But any advice for me so I can salvage the board? What parts should I replace?
My advice would be to strip the active devices, electrolytics and diodes and rebuild it. I'm sorry, but all these parts will be suspect even when on the face of it they seem to work. Stripping and rebuilding with new parts is by far the fastest and surest way. You may be able to re-use the opamps and the LM329's though, just try that after the rebuild.
Jan
