GainWire Mk3 CFA pre/phone amp with very low distortion
The boards are finally here after some time at the custom office. I will send the boards tomorrow, still waiting for malvin payment.
Damir
My balanced version with relays volume controller and inputs selector is slowly being assembled.
Founder of XSA-Labs
Joined 2012
Dadod,
I just built the Shunt Regulator portion of the GW Mk3. I substituted the 8.6v zeners with 9.1v - hope that is not the problem. I only have one of the +ve rails working where the voltage adjusts and I can feel heat burning off on the heatsink. The others are pegged at -19.36v and +18.35v no adjustment possible and no heat from the shunting. Could I have some bad MOSFETs. I added some LED's to show power on each rail. I am also running 0.22R vs 0.1R near the outputs. Otherwise, I am following the specified parts. So where to debug?
600773d1487741995-gainwire-mk3-cfa-pre-phone-amp-very-low-distortion-gainwire-mk3-psu-build-photo-1.jpg
Dadod,
Hi xrk971,
Your heat sink looks to small. A shunt regulator without load will dissipate all power, in this case between 3 and 4 W, depends of DN2540 CC current.
When load connected, in this case preamp part, it will take part of power dissipation, about 1.5 W and the shunt regulator will dissipate less.
Zener of 9.1 V is OK.
Regarding non working side, check all diodes orientation and soldering on back side. Check the mosfets too.
BR Damir
  • GainWire mk3-GNFB-CFA-BOM-b.txt
