diyAB Amp - The "Honey Badger"
I don't think it is V2.4.
draw out your LTP+source resistors, with the two voltages @ +IN & -IN.
Measure the Vgs of both halves.
Mark that on your sketch.
Measure the Vdrop across each Source resistor.
Does that all add up?
BTW,
The k170 datasheet shows ~180mVgs for a 6.2mA Idss device operating @ 2mA.
What should your Vgs be for your devices at your currents?
Built the second board.... this time is even worst, offset near 0.7V and heavy oscilation (11VAC at 400khz)
Tryed changing the drivers but did not cure it.
I am really sad about this
Interestingly it does oscilate even if I disconnect the output devices so oscilation is on the driver stage.... will try to increase base stoppers
Why don't you start with the standard Honey Badger design (which is known to work well), and then start modifying this towards your liking? This might make it easier to understand where/why you get oscillation and DC offset.
