PeeCeeBee
The next PeeCeeBee
Hello people!
A new amplifier has been cooking for some months and a few days ago was finalized. By design it is a detour from our beloved "PeeCeeBee" design. A perfboard version is playing music and tones right now and all I can say is that electrically and sonically it is the step forward for the simple design that has been rocking for the last four years.
The new design is "marginally" complex, uses basic LED biased active CCS, all small signal transistors the easy to access BC556B/546B, emitter-follower VAS with current limit and diode-clamped soft-ish clipping with much less HF distortion than usual, uses input inclusive compensation in addition to usual Miller compensation, produces ~100V/us slew rate, lower overall THD, MUCH less low frequency distortion and MUCH higher damping factor at LF.
I have ordered a couple prototypes of the initial layout. The board would look kind of like the picture (with what Kicad calls "black" mask 😀 ). The PCB is 2 layer PTH. The full test results, schematic and layout will be uploaded in the new thread.
Hello people!
Great going [emoji106] [emoji106] [emoji106]
Sent from my GT-N7100 using Tapatalk
Things that remain the same as the other PeeCeeBees are the feedback network, lateral mosfets, no driver stage, no output inductor, no magics and no secrets. 😀 🙄
The difference is that this time the boards will be available for purchase internationally, with full schematic and BOM :yes:.
The thread will be a DIY build thread (with rules), again! 🙄
Here is a positive slew simulation and a couple real-world test with 100KHz 2.4V 16nS square input and no load connected.
PS=+/-35V, Cdom=50pF, VAS bias=11mA, Input bias=1.5mA, MOSFET bias=30mA, Input filter=1K+100pF.
Pic 1 - Simulation trace with input filter installed.
Pic 2 - Real-world trace with input filter installed.
Pic 3 - Real-world trace with no input filter.
Pic 4 - The humble amp with the 74HC14 signal source.
Guess we are in the safe zone, eh? :cheerful:
Hi everybody
PeeCeeBee V2 boards arrived today. 🙂 very very good quality
Thanks Shaan for amplifier.
Thanks SeedStudio for pcb.
I'm starting to soldering. 🙂🙂🙂
Hi Sam. My pleasure! 🙂
Hi potepuh.
You can. But you must use BC550C/560C or better the 546B/556B (low hFE though) pair at input and MJE350/340 (or any other BJT pair with higher VCE than BD pair) at VAS. You do not need to reduce MOSFET bias.
