Low-distortion Audio-range Oscillator
microphonics comes from low tension winding -- fast/high speed winding which traps air between layers. Besides making for microphonics, any air pockets represents a potentail breakdown point .... lowered reliability when stressed near rated voltage (or lower). The next step is to anneal the part and fuse all the layers together into a solid mass. This slow process is usually not done on low cost caps. REL's RTX is annealed, though.
THx-RNMarsh
Hi Andrew,
As Richard said,
This would exclude the air as the material has bonded together. The cap is only to provide physical protection for the actual capacitor.
-Chris
yellow Wima are old polycarbonate from memory
Exxelia (was eurofarad) still make polystyrene-capacitors caps
the Nissei copper foil Styrene caps are getting rarer and expensive on ebay
Hi Richard,
At Rel Cap, when Bas was making the caps that you helped design
were these some of the special winding machines used to make
the multi wound capacitor?
Please click the pic to zoom in on the cap and the pic from
the Rel Cap catalog.
Shown here is the PPMFX
cap that I'm going to use (one of three different caps, 20uf total)
as tweeter protection in series with the neg line at the tweeter.
It's like 2.5" x 1"x1/2" large. We think we should be fine as that is
around 2kHz fco. I'll actually bring in the tweeter at about 2.5kHz
so there should be no capacitor artifacts.
You can also imagine my surprise when with an old amp I purchased
the "tech" I got it from has bypassed the large coupling caps which
were .22uf x 600V RTX film and foils. He bypassed them with the
crappy metalized poly caps with the spray end caps. : (
What a way to ruin arguably the best performing cap on the market.
It's always nice to meet the daddy of one of these. : )
Hi Richard,
yes, the machine was a newly made one under a NDA to not sell the machine design to others. The MIT logo is there in the early dayz as they were first exclusive to sell to audiophiles. Now the Multicap name has stuck but anyone can buy thru REL-CAP distributors or directly (for large vol).
It is annealed.
THx-RNMarsh
Thanks for posting this. I bought one of the Panasonic 2722's on eBay that you mentioned before and was looking for something to benchmark against. I'm between houses - and workbenches - now and just using a loop-back to learn about the thing.
Richard,
i can follow the arguement for film and foil caps for high current crossover applications. The literature for the Multicaps also refers to filter networks like servos, what performance inprovement in that type of application over a cap like Wima FKP film/foil or MKP metalized end attachment?
