F6 Amplifier
About one year ago, I built a F6 amp. I used the PCB from diyaudio with a little modify, unfortunately my heatsinks are too short so I must cut the PCBs and wiring interstage transformer🙁
Some images to show and hope all of you like it!:smash:
About me, I always love these images because I built this amp at my old home that I was live for 31 years🙄
Nicely assembled . nice workmanship
Immediate impression is the Helluvalot of additional Complexity tho.
Imo it seemingly goes against the KISS basis of the design.
As pointless digression;
there are 'other' solutions to a too short Heatsink, beyond sawing off bits of the PCB...
remembering that Only the irfp240's needs be on the sink 😉
F6 different transformers
Hello Passlab's people 😛
I am thinking of making a new poweramp. reusing my old chassis, capable of dissipating around 200w (AlephJ/F5 etc...)
So i swapped some drivers with some transformers, which i would have been using for the shade enabled poweramp.
I can see, that those transformers are much like the original Jensen F6 transformers, and my quistion is, if i can use them for the F6 ?
I hope somebody a little more experianced into transformers than me, would take a look at the attached two .pdf?'
Jesper.
  • Reichenbach_RE-123-ELCF_output_xfmr.pdf
  • jt-123-flpch.pdf
    jt-123-flpch.pdf
I'am lucky enough? 😀
Directly from Linear Systems.
LSJ74A x 24 and LSK170A x 24
That's for replacement in my F6 amplifer.
Question: do i need to match them or i can use grade A with grade B, or better A with A without doubt?
This is from build thread
Q2 2SK170BL or LSK170B
Q3 2SJ74BL or LSJ74B
(This circuit will benefit from the input Jfets having a similar Idss, but don’t obsess about getting matches down to 3 decimal points — within 10% is more than good enough.)
If they need to be within 2,5 - 6,5mA range (LSK170A) or more i dont know through?
Jesper.
lykkedk
As i understand transistors have A,B,C,D grades with different idss in each grade and where A is lowest noise with idss 2,5 - 6,5 mA, so as i understand (i can be wrong maybe) you need to get one grade and match them to difference of each other not more than 10%. that 2,5 * 0,10 = 0,25 mA. I'am right?
