300b with single stage driver, C3M or?
At first glance one would think the input capacitance of a Mosfet would be an issue but it's not. Here is why. (source follower configuration)
Cin = CGD + CGS(1 - AGS)
The only way it would be a problem is if the gain from Gate to Source was exactly 1, which it wouldn't be. It would be close to 1, lets say .99,
Cin = CGD + CGS * .01 So for a Mosfet with input C of 1200pF it would only be 12pF
Yes, the input capacitance may be not an issue with source follower in most cases, but for an single MOSFET CCS the output capacitances (Coss + Crss) will play an role. An MOSFET with high Ciss probably will also have an high Coss+ Crss, and not very linear...
In cascode configuration, these capacitances are bootstrapped within CCS devices themselves, see CCS performance measurments
But I like an "elegant" solution with low capacitance devices, since single MOSFET CCS is less prone to RF oscillations than cascode stages, from my own experience.
PS.: if stage gain drop to 0.9 from original 0.99 in source follower applications, the 12pF becomes 120pF in an 1.2nF device, and this is common in amps with lateral MOSFETs at output.
I take an foto from my hand drawing notes (schematics) for not awaiting eternally to make an KICAD draw schema... 😀 NF is the ferrite bead. The battery furnishes 1,6V bias and the 3k9 supply dropper is for both channels.
And one photo from my ugly abused prototype 😱😱😀
My µTracer measurements from E810F oscillated this time (need more stoppers😡 ...), but even so I published here to show the outrageous high transconductance for a 300mA/6V3 heater tube! (ex.: 17mA/V with 7mA!)
I know several JFETs witch don't have such gm at that current levels.
I have some E180F, E280F, 6CL6, 12BY7A, EF184, 6FQ7 and some others types. If someone has interest in some bias/curves measurements from these, I'll be happy to measure (and if tube oscillates, I tame the oscillations and I advise to caution against oscillations).
Since µTracer oscillated with E810F, I re-do my measurements. In pentode mode the crazy E810F don't oscillate, so I can estimate the parameters from here. 41mA/V with 19mA anode is crazy for a small tube...
I'm thinking large triode of the dissimilar dual triode 6EM7, 35mA or so, 1:1+1 interstage to PP 300b
The small triode section doesn't get a lot of love, so I am thinking of just leaving it unused and maybe using a 6J5 . If it gives me enough gain.
TBH I symphatize more with the low power section than with the power section of a 6EM7. See the curves, is very good for the low power section. Trouble is, has high rp and mu, so gain will be excessive if using it.
nice you can ,use an 1:1 interstage too 20ma
And will be at a DHT style! Like with 4P1L. I'm using the 4P1L now, instead of E810F. I compensated the low gain (comparing with the E810F) with a 1:4 input trafo, so the net gain is close.
Scary low THD with low level high order H (the important part from a HD measurement). Like Ale Mogliaa published in his site, is a very clean driver.
TBH I preferred the 4P1L sound (and saved the E810F for another project), due to the cleanliness (this time, technical and sound results are "in phase" 😉😀 )
I believe the 2A3 sound in same cleanliness ballpark, but results and preference may vary
DIYbras, the problem with going 1:4 with an insterstage is that the driving impedance the 300B sees is 16 times bigger. Instead of (to assume) 1,2k it will be 19,2k. How is your frequency response?
If I had to use the 4P1L, I'd bet on a three stage design with a 1:1 ITT.
