Super Regulator
Check that R7 is really 1k. Pin 2 should not be at 1.7V with or without the opamp present. If R7 is too low (say 100R) it will pull down the voltage at pin 2 and the diode between pins 2 and 3 will pull down the voltage on pin 3.
Pin 3 voltage should be about 6.9V providing the output voltage is above 8 volts. Pin 2 should equal pin 3 when the opamp achieves regulation.
If R7 is not the culprit there has to be something abnormal in the divider chain from Vout to pin 2 of the opamp.
Here is pic. R7 has color code, brown, black, black, black, purple. That checks out to 1K by my calculations. I will pull at lunch and check out of the circuit.
Purple is not a tolerance colour code.
The brown stripe must be the 1% tolerance code.
that makes your resistor striping to be: purple/violet, black, black, black, brown
for a 5 stripe you have 3 value codes, one multiplier code and one tolerance code. 710 * 1 @ 1% But that does not exist !
Violet would have to be followed by green for 75
That cannot be violet.
You need to measure that resistor. Maybe have to pull out one end to measure correctly.
I suspect that violet stripe is probably a discoloured brown stripe making a 100r resistor.
RGN is correct. IT appears to be 100ohms. 3rd stripe should be brown for a multiplier of 10. There is a .1% violet tolerance code. I will pull and confirm this evening. I still haev the 1K bag. I wonder if they were miss pulled. If so, I will put on my dunce hat and take a pic for all the trouble.
Good advice. 100 ohms would indeed cause what we see, including the 3.something on the LM329.
But it does not explain an output with the B of the pass Q at zero, so that appears to be another issue, apparently solved with the removal of Q2.
I would say, fix the regulation first and then get back to the input circuit.
Note to builders: when building multiple units, finish one first before doing the others ;-)
Jan
All is well. I am sorry that such a bone headed mistake caused so much trouble. Also found 10R instead of 100r on r15/16. Other board has same exact mistakes. I have an empty bag of 1k resistors and a empty bag of 100r. Moved the 100r from r7/14 to r15/16. I still think they were miss bagged as I ordered exact number of resistors, but at this point I will tuck my tail and just be happy with the results🙂. Your welcome for the intellectual challenge of exploring the mind of a moron🙂
Don't go so hard on yourself. Just learn the colour code better and observe what you're putting in.
Buzzforb, glad to hear tou got it going! I am planning on building a couple of super-regs. soon to power Richard Marsh's headphone amplifier.
I use to just look at the colour rings to check the resistor values when there were only 3 value bands and either a silver (10%) or gold (5%) tolerance band. But they now use up to 6, often narrow bands and it can be difficult to tell brown from red. Now I always measure before soldering to be sure.
Rick
Hi all, I have started on my super regulator build.
Thanks Jan for assistance.
Progress is slow as I have to wait for parts that are not available.
I have taken some good advice and started measuring and checking components before soldering.
Pics are included.
Any comments or advice will be appreciated.
