Very simple quasi complimentary MOSFET amplifier
Is Thiago in progress?
Yes, his progress photo from earlier post:
563345d1470415874-very-simple-quasi-complimentary-mosfet-amplifier-20160805_134126.jpg
Nice looking amp
In Stereo, Finally
I now have managed to fix both channels. Both use 2N5401/2N5501 and MJE350. DC offset is stable within 10mV over hours of playing music. Sounds very nice - a nice sweet glass-like mids presentation with very substantial deep bass. Highs are very clear and non fatiguing, easy to listen to for extended periods.
I am running 100mA bias current and dual CRCLC PSU's with 250VA 25AC toroidal transformer for 35v rails.
Currently listening with my transient perfect ScanSpeak 10F/8424 and RS225-8 FAST two-ways. Very nice sound - surprisingly good clear bass.
Setup with power supplies visible:
563440d1470465047-very-simple-quasi-complimentary-mosfet-amplifier-quasi-stereo-final.jpg
Closeup of Unit 1 (left channel):
563441d1470465047-very-simple-quasi-complimentary-mosfet-amplifier-quasi-stereo-final-unit-1.jpg
Closeup of Unit 2 (right channel):
563442d1470465047-very-simple-quasi-complimentary-mosfet-amplifier-quasi-stereo-final-unit-2.jpg
This is the speaker being used:
554260d1465632129-subjective-blind-abx-test-enabled-ff85wk-round-6-10f-rs225-passive-xo.png
Hi XRK,
Now, for the best test......
1. Does the amp engage, does your foot tap and do you feel a heart string pulled from a particularly rendering musical phrase?
2. Can you listen intently without having to get out of your chair and walk away for a 'rest' over coffee.....
3. On sonorous tracks with double bass and deep piano bass, can you hear the real decay of the strings? It should be quite apparent, and needs a very low noise backgroup.
4. If you close your eyes, can you discern, on orchestral music, the rear drums, the right rear woodwinds, the front left and right violins, and the soloist out front? Can you assess their relative depth and width?
For this you need a very, very good CD. I often use the Linn Super Audio Surround Collection Vol 2, AKP284. I use an Oppo 105, stepped attenuator, and SEAS/Peerless speakers.
Very nice pcbs on the component side. Maybe since you have debugged the tracks and clean the grunge, maybe you should lacquer them to protect them from the summer moisture!
Hugh
Glad to see that your problem has gone!
Do you mean that offset is stable between the cold and warm conditions?
Hi XRK,
Yes, the amp has a presentation that is clear, lively, and dynamics are excellent. I listen to known test tracks with well recorded live jazz trios (piano, stand up bass, drums), also vocals from Melody Gardot, Anne Bisson, Diana Krall, pop from various sources, and my favorite classical is Dittersdorf concerto for double bass.
Most definitely, it's the opposite - you don't want to leave or stop listening.
Imaging and soundstage are excellent. I can definitely place instruments on jazz trio. I don't have speakers that recreate large orchestral music well (2 way FAST with transient perfect XO) but for Dittersdorf double bass the attack is very good. Another great source of tests for attack on bass is stand up bas from Chick Corea's trio.
Need 3-way big speakers for orchestral but for simple chamber music and jazz groups, yes - spatialization is excellent. Separation of channels with monoblock amps and PSU's gives excellent soundstage.
I am using a DIY CS8398 DAC with BUrr Brown OPA2604 op amp output that I made (see photo):
563492d1470488210-very-simple-quasi-complimentary-mosfet-amplifier-quasi-stereo-final-dac.jpg
I am using ScanSpeak 10F/8424 mid-tweets and Dayton RS225-8 woofers with my own passive 1st order transient perfect XO. Here are some measurements of this speaker (not with this amp):
HD:
Step & Impulse:
Phase:
Thanks for compliments on construction. Thank you for all your help to make it possible
Hugh
Final verdict is this is an excellent, engaging, muscially pleasing and very dynamic amp. I really like it. Given how many amps I have - this one deserves a real case. 🙂
Thanks XRK,
A really smart analysis.
What is perplexing to me and a few like-minded folks is this:
Why has the quasi topology been cast aside with contempt for about 20 years? This amp does about 0.07% (99% is H2+H3+H4) and on this version this spec is held to 20KHz. In fact with fast bipolars it is 1dB down without LP filter at around 200KHz.
This approaches avoids most of clip issues by using a quasi npn and a bootstrapped nmos. I noticed in sims that the nmos output
stays conducting down to -15Vp. This amp has some very significant features - long live quasis!
Great work XRK!
Hugh
