Revisiting some "old" ideas from 1970's - IPS, OPS
Small progress on power supply board (modifications are just for test).
I'm afraid that is time to desolder some of the power amplifier transistors🙁
I believe that these must be mounted on main heatsink.
To be more clear,Jef i see two points where you type +24v/-24v on power supply board.Is it right? To my point of view this points are connected to main power supply board.
Sorry don't take in account the second picture where the IPS just placed on the OUT.
Wrong direction!
Hi guys, sorry for delay - I use MJE340/350 in bias spreader as this setup is well-tested, providing predictable tempco.
I have never practically tested KSC3503/1381 in this role, except one case - in NS-OPS they are used in a clamping voltage spreader temperature tracking and seem to show rather similar tempco.
Thimios - worth trying it, just watch the bias setting curve during the first tests.
It normally goes a little bit above the desired value in the beginning, coming down to it in 10-15 minutes as the heatsink warms up.
Thanks Valery,i will stay to mje350 as i don't like lifted traces.
Here is the second channel VFA IPS.
