Modulus-86 build thread
Latest member of the Neurochrome product portfolio: SMPS-86.
It's intended to be panel mounted on a panel no thicker than 4.0 mm. International mains in. ±24 V out. 2.85 mV RMS (20 Hz - 20 kHz) output noise.
For more information on the SMPS-86, please see its product page: SMPS-86: Switch-mode power supply for audio amplifiers.
Tom
Well done Tom, the SMPS looks nice.
Having the IEC socket and switch pre-installed is a nice touch. Also like the idea of power LED connecting socket - will make connecting a front panel power LED very easy.
Looks like you have listened well to your customers. 🙂
Thank you. Mains wiring is intimidating to many, so letting me do that relieves some anxiety for some people.
I rather like the little EURO-style connectors. They're super easy to work with. The mating plug has screw terminals, so you attach your wire there and done! Having the ability to unplug the LED is handy during the assembly stages of a DIY project.
The SMPS-86 saves you 30 % on the parts budget compared to a Power-86 with a 160 VA Hammond toroid that is available world wide.
I've been known to do that on occasion. 🙂
Tom
I think you understand that I want to power two pair of 90dB B&W speakers with one amp. I'm pretty sure the mod86 won't be capable.
That depends. If the impedance of the speaker is 4 Ω or greater, the Modulus-86 will work fine. The only exception would be if you need to exceed 110 dB SPL.
Would a Parallel-86 work
Certainly. Do beware, though, that the LM4780 is harder to work with than the LM3886. The LM4780 used in the Parallel-86 has a metal back, thus, needs to be isolated from the heat sink. That's not a big deal, but it is certainly in the "do it once and leave it" category of tasks. The SilPad 1500ST thermal pad that I recommend using between the LM4780 and the heat sink won't allow for repeated assembly/disassembly operations.
would the addition of the SMPS-86 with a Mod86 also work?
The SMPS-86 is an alternative to a Power-86 and transformer. The SMPS-86 provides ±24 V. With the right transformer the Power-86 can provide up to ±35 V when used with the Parallel-86; ±28-30 V when used with the Modulus-86.
With the SMPS-86, you will get lower output power. I measure 28 W (8 Ω) just shy of clipping with the LM3886DR. I expect the numbers for the Modulus-86 to be similar. There is no ±30 V or ±36 V module available for the SMPS-86, so you're stuck at ±24 V. That's the drawback.
Tom
I use B&W's (703's) and although these are classed as an 8 ohm nominal load, the impedance actually dips down to 3 ohms. In practice it has never proved a problem but driving two from one amp could get interesting. I would suggest Henry try if possible to obtain an impedance plot of his speakers... and reviews often publish details such as this. Its not that hard to measure anyway given a DVM that can measure low AC voltage and a slow frequency sweep as a test signal. It would certainly give a useful idea what you were dealing with.
Indeed. In example, here is what the late TJN said about your B&W 703's: B&W 703, HTM7, 705, ASW750 surround speaker system Measurements | Sound & Vision
Best,
Anand.
Driving two speakers in parallel? Why would one do that?
I should probably have asked for clarification, but I assumed Henry was talking about bi-amp (two amps, one speaker) not the other way around.
Tom
powering two pair of speakers
Tom
I'm a bit confused. For some reason I thought the output of my Mod86 would be increased by using the smps86. What are the benefits of using the smps86 instead of the power86? if there are benefits can I use the Antek AS-3224?
Ah 🙂 well you have read my post in the same way that I read Henrys post. I never mentioned parallel.
Asking the above question made it sound as though this was something a little different to running a stereo pair from a stereo amp.
running two pair
Tom
I'll try to clarify my earlier post.
I was asking about using a Mod86 to run a pair of stereo speakers in one room, and another pair in a different room, at the same time.
I think that question has been answered and the Mod86 is not the amp for that application.
For many years I've run a pair of stereo speakers in one room and another pair in a different room at the same time. The various amps used had outputs of 100W, 125W and 200W into 8Ohms. All three had up to double the power into 4Ohms and the big one had lots of power at 2Ohms.
I'm thinking the Parallel86 is the way to go. Am I missing something?
Thanks,
henry
For background music (so maybe a few watt at the most), either Modulus-86 or Parallel-86 will work. If you really crank it, you'll need the Parallel-86.
Just beware that the LM4780 IC used in the Parallel-86 is getting hard to find at the official distributors due to TI's discontinuance of it. Also note that this Friday (22nd) is your last chance to get in on the Parallel-86 group buy.
Tom
The aspect of the Mod86, I love most, is it's non-fatiguing sound. Even with my other two highly rated amps horns, playing high notes, can sound strident. Large orchestral crescendos can also be hard on the ears and not clearly convey the sounds of individual instruments. One of the amps cost $3,500. Overall I can listen to the Mod86 for hours and it has none of those unpleasant qualities. It sounds great. Great job.
Oh, and after three weeks of listening, to the Mod86, it is now in the cabinet and the other very good amp is for sale.
Your more than welcome. It has been a pleasure, fun and a learning experience working with you.
So, do ya think the Parallel86 will work for me with the two pair of speakers setup in two different rooms? It seem to me the Parallel86 has the power. But, as you well know, I'm new to this whole diy amp thing, so have to rely on people I can trust. You have my undoubted trust.
