Pictures of your diy Pass amplifier
Nelson thanks !!!!!! for giving this excellent Amp to the DIY community.
Specs:
Dual mono implementation.
Two cases one for the front End (BA-3 gain stage) and one for the complimentary final stage.
Front End
BA-3 in cascode mode powered by Salas Shunt Regs at 55 V.
Final Stage
CLC Power supply.
Transformer 1500 VA - 328,000μf - per channel at 55 Volts.
12 Mosfets per channel.
Bias 300mA per Mosfet.
Amp weight 78 kg.
Dims: 430 x 200 x 700 mm.
WOW....really inspiring work....
Congratulations ....amazing ....the amount of thought and planning is evident.....just WOW😀
Specs:
Front End
Final Stage
CLC Power supply.
Amp weight 78 kg.
Now that is bloody awesome mate.
I couldn't suggest one thing to improve on that.
Jesus.. 😱
A few more
Smallest F5 style amp?
Hi
This feels strange to post here after the fabulous extreme built from Nikos but here it is the possible smallest F5 design style amp...it uses an F5 board f rom eBay but with Toshiba output for audio, lower source mosfet resistor values, a bit smaller current in input stage too and a gain of 10 instead of 5. The damping factor is about 30 compared to the original F5 which is about 80 nominally.
Since the very small size (240mm x 250mm x 120mm) it is only 8 Wrms class A and maximum 15Wrms in class AB with 8 ohms. Power supply is double mono , each side having 100VA transformer and 72K uF capacitance.
Comparison with another amplifier size...:
Fab
