freeDSP - an open source 2-in 4-out digital crossover board
Hello Jiri,
there is currently no group buy for the freeDSP CLASSIC. However, you can download all necessary files to build one yourself on the website. If someone prepares new kits, we will spread the news in the newsletter, which you can find as well on the website.
Best,
Sebastian
Hi there,
I had freeDSP soldered recently, and for the last couple of days I've been struggling to make it work. The firmware is passed to EEPROM via Arduino Nano, but it seems that ADAU1701 doesn't read it on startup and I don't get any signal on output.
Things I've checked:
1. All pins that should be driven to ground or 3.3V are fine.
2. Current consumption of powered ADAU1701 is 106 mA (quartz enabled) or 60 mA (quartz disabled). The numbers fall in normal range from datasheet.
3. Firmware can be written to EEPROM and can be read by Nano.
However, not everything was fine:
1. ADAU17071 pins 13 (1.8V digital supply) and 14 (GPIO) were short-circuited for some time.
2. I didn't find 2N7000 transistor and 24AA256 EEPROM at my local store, so I bought BSS295 and 24LC256. Later I found out that EEPROM is written with 4V instead of 1.8V, and 4V is the maximum voltage ADAU1701 can tolerate (as per datasheet).
With this points in mind, I'd like to ask following questions:
1. Is it likely that my ADAU1701 is dead? How can I check it?
2. Can anybody provide a simple SigmaStudio project or hex file that is known to work on freeDSP (something extremely simple, like [white noise] -> [DAC] or [ADC] -> [DAC]).
3. Can I verify that firmware is actually written to EEPROM and then read by ADAU?
Any other feedback would be appreciated. I have got a multimeter and Hantek 6022be oscilloscope for debugging.
Thanks!
I have issue with my freedsp board, and Ludwig looks very busy to provide me support.
I made a simple code - attached bin and hex files renamed as txt for diyaudio forum
I uploaded it to the EPROM - ok with a non standard method:
I used a raspberrypi.
But I check the eprom code by switch off and on the power of the raspberry pi, restarted it, and the eprom code downloaded is the same as the eprom code uploaded.
The DSP is powered by the +5v of the raspberry pi. Led is green.
Sound is plugged on ADC0 and 1 - I checked the input source with my amplifier - OK
Nothing is outputed from my freedsp on VOUT-0 to 3
can someone can check my files? Or help me to debug my errors? Or send me a simple valid bin file?
many thanks
As for me, I've never managed to upload firmware to ADAU1701 just by writing binaries to the EEPROM (24LC256 in my case). Neither using proposed Arduino Nano approach, nor using other MCUs. The thing that worked out was to pick SigmaStudio HEX file, convert it to Intel hex format using "Sigma Studio Hex File Converter" tool and then upload the resulting file via a clone of Pickit 2 programmer.
Many things can be a potential cause. Bad Nano (in my case), wrong padding bytes (maybe 0xff instead of 0x00 to fill the rest of EEPROM?), wrong program placement. Unfortunately I've never investigated why this had happened to me and what to do if don't have an EEPROM programmer.
Please, can you post a simple hex file working fine with the ADC in and out ?
It may help me to understand if I have a hardware issue
I don't have FreeDSP any more, but the attached file was definitely working. It is an attempt of creating a guitar overdrive effect, probably with unreasonably high gain, so please don't expect clean sound.
And I'd say it's unlikely that you do something wrong when creating a hex file.
FYI,
I have a couple of freeUSBi bare PCBs available if anyone needs as I ordered a bunch of them from Elecrow. Usual Elecrow quality, red solder mask. 2 euro per piece plus postage, 2 euros Europe, 2.50 euros elsewhere.
