Bruno Putzeys Preampli - GB for the 6 Input Board
Uhh??? I missed this GB and only 10 days from start of thread to finish - amazing effiency! That will teach me to only look at subscribed to threads ...
Do you have any SMD soldered boards and selectors left I might be able to purchase please Enrico? Just one set would do .
(I do already have your original board Enrico... still not got around to learning to SMD solder yet.)
Hi Nat,
You are right, this was a very fast GB... I still have the parts for 2 boards, so no problem.
Best Regards,
Enrico
You mean the 6 input board only with the SMD only? Yes of course 🙂
Err.... the board with the SMD bits on and the board with the rotary switch on it. Is that the same as you said? 🙂
1 x
1 x
Nat, I can give you the board for selector and the board for the 6 inputs with all the SMD parts installed. About the other parts through holes, I am sorry but I don't have them available... you have to buy and solder by yourself.
Sorry about that.
Enrico
Enrico if you have any more boards, with or without parts. I would be happy to purchase one.
David
Hi David,
I still have one board with parts. It's the last one, with a small defect in the PCB that I didn't noticed when I build the board... As you can see it's just a corner but it's better you know.
And I have still few bare boards...
Enrico
