BAF 2015 Coverage
It appears while us mere mortals have been sleeping the mad scientist has been sweating away in his laboratory quietly working burning the midnight oil. I was going to say do not tease but tell us what 50 watt Class A SIT mimicking amplifiers sound like but I see that is reserved until 6moons publishes the article.
The one and only
Joined 2001
I'm thinking of using something like this on the supply. Any other suggestions welcome.
Here is one with an added resistor. This allows you to use a higher
value for the RC filter. If you used a higher value in the original the
voltage regulators (in the case of TL431) might not bias up, and if
instead you solve that problem by making C much larger, you might
see some motor-boating on the circuit.
:cool:
:cool:
Thank you Nelson.
I'll give that one a try.
Sorry to be late in replying - away for the weekend.
I was able to get the original Schade circuit stable at 1.8 - 2.0 amps
To be make sure it wasn't my wiring I brought up the generg circuit (below) - only required a couple of changes (gate resistors and bias supply).
With voltage at D1 = 50V and D2 = 25V. R2 = .33 ohm and R4 = .5 ohms. Current through these resistors is 1.5A. Rock solid.
I want to build the other channel and give a listen.
I also want to try a IXFN/2SK182 version with 60V supply and then I will try to resolve the IXFN/IXFN version.
Best
Bob
This is interesting! What typical values in the components is there ?
Assuming you have 70V of unregulated dc coming off CRC, and intend on using IRFP240 or 250.
First Diode. 1N4004
Zener Diodes: 6 x 11V (or any other combination that gives you between 64V and 66V)
Top resistor between 1k and 2k to feed Zener network adequate current.
For RCR network at gate of mosfet. I used 220 Ohm 1000uF 220 Ohm. You could also use something like 1kOhm 200uF 1kOhm.
Quite a bit of flexibilty on those values.
Mosfets: whatever you have with decent transconductance. IRFP240 and IRFP250 are good examples. They are also cheap.
Note: If you have less than 65V of unregulated supply voltage coming off CRC you can either accept a lower regulated supply voltage, or alternatively you could try using depletion mode mosfets which will give you a higher regulated supply (around 4V higher) voltage compared with IRFP devices.
@wdecho
I haven't listened to anything yet. Just one bench proto of each to confirm the basics before getting boards ready for the chassis. They're monoblocks, so I won't have enough chassis to listen to them all at once anyway. There's a good bit of work to be done still, so please don't let me distract you. I'm months away. :)
any news regarding the status of the work? :) ( forgive me please my impatience, but very interested in this amp ;-) )
