Vacuum Tube SPICE Models
I would like a model for the 6AC7 if anyone has one. Many thanks.
I did eventually find a 6AC7 somewhere on the net, by Steve Bench. I have not verified its accuracy. I did use it for a couple of sims and I noticed a higher noise floor and lots of odd order harmonics going well up into Mhz range, when compared to other tubes in the same circuit. Both in pentode and triode. Not sure that's due to the model or the tube characteristics.
.SUBCKT 6AC7 1 4 2 3
+ PARAMS: MU=49.9 EX=1.47 KG1=435 KP=162 KVB=12.3 ; KG2=415
+ CCG=11P CPG1=.015P CCP=5P RGI=2K
RE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
*G2 4 3 VALUE={(EXP(EX*(LOG((V(4,3)/MU)+V(2,3)))))/KG2}
g2 4 3 value= {(I(G1)*100/(V(1,3) + 100))} ; models change in current with change in plate
RCP 1 3 1G ; FOR CONVERGENCE
C1 2 3 {CCG} ; CATHODE-GRID 1
C2 1 2 {CPG1} ; GRID 1-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
R1 2 5 {RGI} ; FOR GRID CURRENT
D3 5 3 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
I don't have it coded into a Spice model yet. However, it should be straightforward to take the above formulas and create the Spice model.
Perhaps this should work -- the tube is 6AT6
.subckt PENTODE 1 2 3 4
+params: KG1=0.003751 kp1=-2.491 kp2=3.935 kp3=3.716e-5 kp4=0.1675 kt1=29 kt2=0.2549 kc1=7.829e-4 kc2=6.068e-2 kc3=1.098 ks1=-3.567e-6 ks2=3.267e-3 ks3=-1.38e-2 kcs=0.09196 ecref=0 esref=250
E1 7 0 Value = (V(1,4))
E2 8 0 Value = (V(3,4))
E3 9 0 Value = (V(2,4))
RE1 7 0 1e12
G1 1 4 VALUE =(KG1*V(7)+((kp1/(kp2+v(7))+(kp3*v(7))+kp4)-KG1*V(7))/(1+EXP((KT1-V(7))*KT2)))*((kc1*V(8)^2)+kc2*v(8)+kc3)*((ks1*V(9)^2)+ks2*v(9)+ks3)*(1/(1-kcs*(V(8)-ecref)*(1-V(9)/esref)))
RCP 1 4 1e12
C1 2 3 2.4e-12
C2 1 2 3.9e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.model dx d(is=1e-9 rs=1 cjo=10e-12)
Runs under Multisim:
Looking forward to seeing the screen grid current... btw, I could not get the above model to run under LTSpice.
Needed some curly braces in just the right spots.
E1, E2, E3, G1 lines.
Code:
.subckt PENT 1 2 3 4
E1  7 0 Value={V(1,4)}
E2  8 0 Value={V(3,4)}
E3  9 0 Value={V(2,4)}
RE1 7 0 1e12
G1  1 4 VALUE={(KG1*V(7)+((kp1/(kp2+v(7))+(kp3*v(7))+kp4)-KG1*V(7))/(1+EXP((KT1-V(7))*KT2)))*((kc1*V(8)**2)+kc2*v(8)+kc3)*((ks1*V(9 )**2)+ks2*v(9)+ks3)*(1/(1-kcs*(V(8)-ecref)*(1-V(9)/esref)))}
RCP 1 4 1e12
C1  2 3 2.4e-12
C2  1 2 3.9e-12
C3  1 3 0.7e-12
R1  2 5 2000
D3  5 3 dx
.ends
A mediocre type 47 pentode model attached.
If anyone has better model, please inform.
**** 47 ******************************************
* Created on 02/24/2016 15:00 using paint_kip.jar
* Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively
* Plate Curves image file: 47.jpg
* Data source link: <plate curves URL>
.SUBCKT PENT_47 1 2 3 4 ; P G K G2
+ PARAMS: CCG=3P CGP=1.4P CCP=1.9P RGI=2000
+ MU=8.6 KG1=2995.6 KP=38.2 KVB=32.6 KVC=1.57 VCT=0.0139 EX=1.3 KG2=0
* Vp_MAX=520 Ip_MAX=80 Vg_step=4 Vg_start=0 Vg_count=8
* Rp=5000 Vg_ac=15.3 P_max=7.5 Vg_qui=-15.3 Vp_qui=250 UL=0.43 EG2=240
* X_MIN=182 Y_MIN=191 X_SIZE=782 Y_SIZE=480 FSZ_X=1616 FSZ_Y=876 XYGrid=false
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=n
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=y harmonics=y
RE1 7 0 1G ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
+{V(4,3)/KP*LOG(1+EXP((1/MU+(VCT+V(2,3))/V(4,3))*KP))}
* Alexander Gurskii screen current, see audioXpress 2/2011
RE2 8 3 1G ; Dummy
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG2*(KVC-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0} ; Dummy
C2 1 2 {CGP} ; GRID 1-PLATE
.ENDS
