A Bookshelf Multi-Way Point-Source Horn
All I need now is plans for a horn profile that suits the job and I can spin the primary shape on my wood lathe.
Any thoughts?
I guess this is only going to be easy'ish for symmetrical shapes... Hmmm
That plastic diy vacuum forming video was pretty cool - very nice professional looking results. It is rather thin though so will need to have some sort of backing to stiffen it.
One idea is if you have access to a horn or WG now that you like, make a positive mold with it using plaster of Paris - just plug up the throat and insert a divider so that you only make a half mold form at the middle plane.
Then vacuum form around the plaster mold. The original wave guide should clean up nicely. You could go into production with this method.
After listening to this speaker I can see that a higher quality woofer would be more appropriate to get the most out of the sound quality. I have decided to upgrade the woofers with a pair of RS180P-8's that are on order. These are a little smaller but have higher sensitivity (90dB) and more xmax. Most importantly, they have a cast alloy frame and more advanced motor with shorting rings to reduce distortion. I did not get RS225's as those are much bigger than the DC200's and won't fit in the box.
Nice New woofers x.
Your points on the already developed horn rings true. Its all a matter of how much I can land a pair in Aus for... And how much effort/cost it will take to build my own.
If I could refine the process well enough I'm sure many aussies would go for a pair of two, especially in the diy doof seen down here.
Yes, I would plan to build up the horn wall in layers.
Wesayso... I haven't looked at the Ariel thread in years. I'll head over and have a look.
Cheers gents.
I haven't kept up with this thread, but looking at the updates in the first post, I am having a hard time believing the polar measurements.
You have - 6db point at 60 degrees at 50 Hz? How is this possible from a smallish horn? Something weird is going on and I would double-check the polar measurements.
Cheers gents.
Azurahorn AH-425
Azurahorn -Le Cleac'h Acoustic Horns - Products
AH-425
The AH-425 has a mouth diameter of 420mm and an axial length of 260mm to a 1.4” throat. Commissioned by Lynn Olsen for the ‘Beyond the Ariel’ project (see thread on diy audio)
The Le Cléac’h flare rate is 425Hz at 0.707 T factor calculated from a 1.4” throat size.
A bit different from the horns on this thread. But I think it could be worth it...
1.4" throat, just like the 18-sound XT1464. Not bookshelf material but interesting...
Those polars were the result of the open back (dipole) woofers, the later polars with the sealed woofers look "normal", pattern going omni below around 600 Hz.
Ah, ok. But if the measurement is accurate then we may have accidentally stumbled upon an approach to control directivity down low without the negatives of traditional dipoles, i.e., dipole peak, EQ, power hungriness.
The response required plenty of EQ to flatten, the negatives were still there. That said, the phase (and frequency) response of the driver's output on the horn side is different than on the open back, so there are differences between this response and a "traditional" dipole.
Also, the measurement angle of the single woofer was different compared to the on-axis direction of a "traditional" dipole, and probably would not look the same if rotated the opposite direction.
He did remake this measurement a little later and got this:
Look at post #427 here.
Here is a more accurate set of horizontal polars - all measured! Directivity is lost around 500hz which is correct for the horn specs. Just shows how inaccurate 'freehand' is, but I was only doing quick and dirty measurements first to look at the CD up top.
This thread is moving so fast that it's hard to keep up with the results 😉
/Anton
Thanks for the links wesayso.
The prices are way out of my league though and we have our first baby arriving in 6 months so the purse strings are automagically starting to tighten on the sound budget.
I'm sure it will be well worth it though. ;P
I'm also mad enough to build my own, for better or worse.
On a side note, I just got all the wood cut for a pair of Arts SynTripP 's. I think the throat is 1.4" so now I'm wondering about fitting the SB65 to them...
Then I just need a 10" domestic version of the Xoc1 tapped horns or similar and the party really starts... Bananas in pyjamas at 100db anybody?
Hmm, insert evil laugh!
My RS180P-8's arrived yesterday - amazingly 2 days after order was placed and free shipping too. I have to say, I am quite impressed with their build quality: top notch cast basket with crinkle paint finish, great neatness of glue and fit and finish, nice paper cone, solid aluminum phase plug, a large beefy magnet, and built-in EVA foam rubber gasket on the bezel rim backside.
To top it all off, the first thing I do when new drivers arrive is I put them to the TS parameter test with a DATS v2. These drivers measure spot on within 2% of all critical parameters like: Qms, Qes (and Qts), Mms, fs, Vas (was a little more off at 24 liters vs spec 22 liters but not a problem) and the surprise was that the Le was much lower than quoted at only 0.2mH at 10k. Anyhow, when a Qts spec of 0.34 measures in at 0.35 - I am happy. Also, the predicted sensitivity was almost spot-on too, coming in at 89.5dB at 2.83v.
Dayton does not exaggerate their TS parameters like some manufacturers. This driver is a great value at $51 for a 6mm xmax 89.5dB driver.
These will be swapped over for the DC200'8's shortly.
New upgraded stealth finish. Van damme studio cabling and 4 pole speakons used. Stuffing done. Measurements to follow.
