Shigaclone MKII Black - The builders Thread
Dears,
The quotation from the manufacturer has came back, the quotation for 10 piece of remote control is $180HKD (around 22Euro and 24USD).
But it is not including the surface marking.
I will try one more manufacturer for comparison
It is good that now there are 10 person show interesting-:
1. comickitkit
2. syklab
3. angcl
4. tubo
5. Guarnera
6. jims
7. Fabian85
8. tomw
9. turbo
10.PHansen
To minimum order quantity, anyone still interested?
Tibi,
I have a question on how it should be done correct connecting of 4 Salas Reflektor-D to shiga's V1-V2-V3-V4 . As you said regulators gnd have to be tied to J6 gnd . There's two schemes in attach can you just take a look and say witch is better. I think it will be very tricky to connect 8 wires to small gnd pad of J6 ,the way to connect is to solder some wires (marked orange color) from V1-V2-V3-V4 gnd pads to J6 gnd pad under side of board.
Thank you
Tibi,
Thank you
Hi Nicolae,
Left picture is the right one.
Do not forget to remove inductors L2 and L4.
Tibi
Hi Tibi,
As mentioned before, I have replaced the original Tentlab clock by adding Neutron Star Clock with separated power supply and the miniregs on V3 is still powered from 8V common point by a little cable. Will it still working for V3? Do I need to disconnected it and facilitate to V1 or V2?
Comickitkit
From Romania Shiga MKII fan club 😀
Congratulation to Marian Apostol for a wonderful CD player.
Tibi
