My Holton amp builds.
My last Holton build is an 800L.
Modushop 5U 500mm chassis. It mabye oversized, but it gives me romm for some extra bias 🙂
2 x 750VA 2x55v toroids. Holtons PSU-Three with Elna 10000uF 100volt. And ofcourse the PowerOne 3.0 board.
And working on another, 500V1 boards, changing the cheac yellow caps with Nichicon fine gold 47uF 100v caps. And changing the blue resistor for zobel with Takman carbon film. Some say that this is a good uppgrade, lets see ore hear 🙂
This is what my Holton amps are working with 🙂
Diy towers with 8 Infinity Emim midranges and one Emit tweeter. I think final version will have 9 Emims foreach tower.
Bass tower are Dayton PA-380 12" woofers 6 for each tower.
Corner sub is Ficar IB18, 2 for each side.
Al speakers are dipole !
The Holton 500V1 is now playing, first impression is very good as alway with Holton amps.
Holton chassis.
Toroid from Adyton XP3D 1000VA 2x56V.
Psu is a mix of Roe 2200uF 100V and Nichicon 2200uF 100V 20 pc for aech side giving 44000 uF for each channel.
PowerOne v2 and soft start,
Neutrick gold Xlr. VanDamme xlr mic cable.
Gaofei speaker terminal wit MIT T2 cable.
Al power cables is solidcore 2,5kv.
Some more work on the 50L, thrown in some stuff to see if there is room for everything.
2x50L boards.
2x 630VA 2x25v
2x 50VA 2x32v
40pc Nichicon KW 2200uF 63v for each channel.
PowerOne
And som more stuff.
As usual al solidcore for ac and supply for the amp board.
The chassis is a 4U modushopp with Pass look heatsink.
3 heatsink for eatch channel each is 12cm wide, 18cm high and 6,5 cm deep.
