100W Ultimate Fidelity Amplifier
I make AX16 simulation.
I modified it and made a PCB layout.
If the value of the components of the schematic is different from simulation file, the simulation is the correct one.
Hi Bimo,
Is this a Sprint file? Would you share it? If not. could you attach a mirror of the silk please? I would be willing to build this.
Blessings, Terry
Hi Terry,
attached is the mirror silk. I have cleaned dark mount holes a bit. design is in eagle and I know the export in pdf is a bit ugly. Pl let me know if this is what u needed.
reg
prasi
There is a trace that is not connected. Is that by design?
Yes, it's much better, primarily because of R9 cursor in the event of interruption (in time may compromise the wiper resistance) does not cause the emergence of the offset voltage in the output stage.
OK, I revised it.
