The question is what is the probability that the output of the amplifier have +/-7V DC offset. Many protections have similar circuit for dc detection (working amp have output DC offset about +/-50mV max and broken is on rail voltage about +/-50V). If necessary I can modify circuit to have the +/-1V DC sensitivity.
Please do it!
Please do it!
It has already been done in the previous post, and this DC detect is from F100 PSU+Protect.
Yes but the goal is to avoid the relay.It has already been done in the previous post, and this DC detect is from F100 PSU+Protect.
Like this
Now we need someone who can redraw the pcbLike this
I agree
I like to take part in this project , I mean to layout the PCB .....
Please do, but share lay file too.
This DC protect have AC off detect circuit to fast switch off relay and about +/-1V DC detect circuit.
Mr. Mile,
What would be the required AC supply voltage for this DC protect circuit?
Is this circuit applicable to any types of DIY amps?
Vinski80
Mr. Mile,
Vinski80
AC is 2x25~40v from main transformer, protect can be use with any amp.
Thanks. I'm so excited to build this stuff.
By the way, will this circuit also protects the output transistors(amplifier unit) if ever the speaker terminal or the speaker itself shorted?
vinski80
vinski80
Yes if PRO pin is connected to emiter of NPN output transistors in positive rail.
It looks like the PRO portion is missing in the latest protect circuit
PRO portion is add, but will work only with AX16, HV23...
- 100W Ultimate Fidelity Amplifier
