Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
DAM Super Regulator
I can make a super regulator simply adding 1 transistor. Is better than a separate power supply and Floating mass.
It is similar to that proposed by AECM but short in the R sensor Instead in feedback capacitor.
After several transistor based schemes, I came to a final one. And from my point of view it looks the best one in my oscilloscope. Even better than Soren’s mod proposition.
The last scheme
I used the original buffer scheme, but modify it to become as a pure follower.
The feedback at the emitter of transistor is a Sulzer Super-Regulator. Provides +4 and -4 vol. Vout Instead of +3.4 and -3.4 vol. Vout proposed by AECM circuit.
attachment.php
The output impedance similar that a Super-Regulator Jung. And haven't oscillation, is stable.
attachment.php
@Oneclock, did you also try simulation with the original 500 ohm sense resistor still in place? It should lead to better balancing of inverting and non inverting input bias current. Also one less component to change...
Yes.🙂
In the impedance simulation is identical result a short or 500 Ohm. Then you do not have to do anything, resistance is OK. Short is no necessary.
Oneclock,
How is the sound after mod with transistor, if compare it with other mod. Big Step or only improve in figure?
I think it's an improvement.
I will compare with other DAM1021 mod.1 0.1 / 0/499 4x 1000uF (ESR 0007). It has spectacular treble that mod.1. Now also has spectacular bass. But I hope to compare with other people. It may be suggestion.
Yes, you can.
Yes I know that 🙂, but at HIFIDUINO it is said:
"I took a closer look at the J2 connections on the backside and the board and the +/- analog power connections are connected to the power lines after the RC filter. If you power through J2, there will be a 12 ohm resistor to the filter/smoothing caps. This would not destroy the board, but it is not the right design/thing-to-do either. Thus there is no good reason to power through J2.
