TPA3251d2
It's self built. An OPA627 as a difference amplifier proceeded by some large polypropylene DC blocking caps and a resistor divider. This then feeds into the soundcard. It's part of a box I made that contains PGA mic pre amps from TI and a jig for impedance measurement too.
I had thought that my setup could be at fault but this is a balanced amp and with no load connected I get distortion as you'd expect. The measurement box is only measuring a voltage as the load is entirely separate. Only when I add the load in I get significant amounts of 2nd order distortion at low frequencies. I will be posting more measurements laterr on today, but comparisons and a discussion could prove most useful.
For those who want to know:
attachment.php
Anyone is getting more than ~85W cont. output power from their implementation? (34V, 1khz, both channels loaded with 3R9)
Working on it...Board stuffed except for connectors, just need to ask the machinist at work to do some machining of the heat sink.
"Big inductor" list:
COILCRAFT RFS1412 10uH 6.2A(10%L drop) RFS1412-103ME
WURTH WE-PD SMD 10uH 10.5A(10%L drop) 7447709100
SUMIDA CDEP 10uH 11.5A(10%L drop) CDEP147NP-100MC-125
COILCRAFT SER2900 10uH 13A(10%L drop) SER2915L-103KL
COILCRAFT SER2900 10uH 18A(10%L drop) SER2915H-103KL
WURTH WE-HCF SMD 10uH 22A(10%L drop) 7443631000
COILCRAFT SER2900 10uH 28A(10%L drop) SER2918H-103KL
WURTH WE-HCF SMD 10uH 34A(10%L drop) 7443641000
