diy short circuit protection
Hello
greetings picture attached of mosfet relay from esperados ultimate
protection how many ampere current could this mosfet relay handle
each mosfet is 37 amperes 100 volts
warm regards
Andrew😕
Hello Tomas
greetings finished it will check it tomorrow some other short
circuit protection circuits being tested
warn regard
Andrew😉
Congratulation. I can not belief that a simple circuit worked out so good. I forget to mentioned you that can add the second channel to the output of the op amp since the comparators output are an open collector. That will make an OR gate. Any one of the two channel with enable the flip/flop.
Hello Tomas
greetings first of all many thanks for helping me out on this project
its working good all the credit goes to YOU protection is vital for
amplifiers i have tried another short circuit protection at over 1200
watts i am trying to diy a solid state mosfet relay need about 50 Ampere
SSR hoping i can make it
warm regards
Andrew
Hello everyone!
I take this thread to ask a quick question.
AMB laboratories offers a headphone amplifier for protection but putting a suitable relay the following diagram it may be appropriate for a power amplifier?
Thank you!
Hello
greetings i have a small problem tried 2 circuits from the web overload protection
using emitter sensing when speaker wires are shorted 12 volt relay keeps going
off and on is there any way this can be solved can anyone help me out
warm regards
Andrew
