All RaspberryPi I2S cap PCB adapters shipped today
All RaspberryPi I2S cap PCB adapters shipped today🙂
Except:
1 wengtech
18 Malvin
19 EHYeon
26 ed linssen
27 supra
Please PM your shipping address to me ASAP
Ian
Except:
1 wengtech
18 Malvin
19 EHYeon
26 ed linssen
27 supra
Ian
Hey Ian thanks very much!
I'm still waiting on the FIFO - seems stuck in customs for 6 days now 🙁
Thank you, Ian
Except:
1 wengtech
18 Malvin
19 EHYeon
26 ed linssen
27 supra
Ian
Hi aive,
Please don't worry🙂 They might be just on vacation😀
it will be received soon.
Have a good weekend.
Ian
Hi aive,
Ian
Hehe not worried Ian, it'll get here soon enough - I have to wait for Crystek clocks to be in stock at Digikey anyways!
Have a good weekend!
Ian,
would it be a good idea to create an I2S cap PCB adapter for the Amanero as well?
Hi fordgtlover,
It would be possible. That's a good idea.
Ian
Hey Ian, I got the goods! Thanks again.
This is going to seem like a really dumb question - but which positions do I place the resistors and capacitors on the SMT XO adaptor PCBs >< I can't tell where they go ><
Thanks Ian.
Thanks Ian.
Open source Arduino based FIFO controller
I’m gonna release an open source Arduino based FIFO controller very soon.
Source code of that FIFO controller will be posted. You can build the controller by yourself with that source code🙂.
Please follow my Twitter for update.
Ian
Ian
Thanks Ian.
Oops I mean, where do the supplied capacitors go on the SMT XO adaptor PCBs? (there aren't any resistors sorry, my mistake)
And are they required if I use CCHD-957 clocks? 🙂
Edit: nvm, I found you had already answered these questions 🙂
XO Adaptor Manual:
http://www.diyaudio.com/forums/grou...-s-pdif-fifo-kit-group-buy-8.html#post3093337
And re CCHD-957 decoupling caps:
Yes, it does. You don't need the MLCC for CCHD-957.
Ian
Thanks Ian.
Hi aive,
Sorry for the confusing.
At back of the XO adapter PCB, two 0603 0.1u(104) MLCCs go to the smaller footprints, one 0805 1u(105) MLCC goes to the bigger footprint.
You need those capacitors for any XO to reduce power supply ripple caused by the inductor of the lead.
Ian
Hi aive,
Ian
Hey Ian, thanks for reply! I must have very bad eyes, cus the footprints all look the same size to me >< But I found your instructions in previous GBII 😀 so I will install capacitors as per photos.
Good luck🙂
Ian
Ian
Hi Ian,
Ah, now I'm confused.
Are these caps still a good idea with use of Dual XO when supplied by external DC to J5 and with FB L11 removed ?
(ref: DualXOclockboard.pdf page 4)
It works fine without the caps CCHD-957's (to my ears) but now I wonder if further improvement could be had.
Thanks.
L.H/S
Hi Ian,
Thanks.
L.H/S
Hi L.H/S
Technically it will be a bit better for reducing noise with those capacitors. Some noise is caused by the inductance of the lead and PCB trace of XO itself(not from power supply) , those capacitors were designed exactly for that case.
Of course it will work fine without them. So, the finial decision will be made up to your preference based on your real listening experience 🙂.
Ian
I started a new thread for an open source Ardunin based FIFO controller project.
Welcome to take part in this project. Please have a look if you are interested in.
http://www.diyaudio.com/forums/digi...-ian-fifo-controller-project.html#post4439423
IanFIFOcontroller by Ian, on Flickr
Ian
Ian
Received the pi adapter!! Thank you!!!!
Good to know that. Thank you for your update. Looking forward to your good news.
Ian
Hi Ian
I actually meant to say WaveIO rather than Amanero.
Do you think you are likely to make a PCB adapter for the WaveIO?
Cheers
Cheers
Ian,
Hi fordgtlover,
Ian
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
