Pictures of your diy Pass amplifier
Aleph J finally finished...
I promised to post more pics when the top plate and frontpanel were done.
So here you are... 😀
Walter
The mesh is attached with 3M VHB bonding tape. Very strong stuff... And also on the four edges some dots with the glue gun. To seal the bonding tape, I put some ordinary black tape over it.
The mesh is right above the 16 x BYW99 rectifiers with heatsinks and they run pretty hot. Around 60C at the heatsink.
Push button is connected to a red Ebay soft start indeed. Same as in F5Tv3.
Walter
Walter
Thanks for the tip on the VHB tape. I will use it on my next project.
Is the power for the LED portion of the pushbutton from the PSU board or from the red Ebay softstart?
Nash
