F6 Amplifier
F6 with a diamond BJT input buffer:
Black is the diamond buffer.
Red was the J-FET buffer.
I probably need to design a PCB for the diamond buffer version also...
BC546/556 was used in the diamond.
Joined 2010
Nearly there - F6 using cree SiC fets
Nearly there, Just a bit of chassis work and testing to go.
Twitchy to set the bias/offset. Wish I'd used multi turn trimpots now! currently biased up to about 1.6A, and the heatsinks are apparently at about 55C
Once I have it roughly set up I'll try an run it through a basic pc THD test.
I just noticed after many months of use of my F6, that it has the tendency for the output to swing little bit on offset, making my full ranger to go back in terms of cone movement and then settle back. Is it normal for F6 to behave like this, or did my power supply alter it's behavior off-late. Don't know what it is because, I did not notice before.
Thanks in advance.
6L6
Moderator
Joined 2010
What ZM said is best, but what you suggest will work, start with one channel at a time (Disconnect PSU from one channel), have a meter across a source resistor and don't be surprised if you need to turn it down quickly.
Bit it also depends on the Vgs of your specific Mosfet and the Zener voltage... I used 5.1V in the beginning and couldn't get enough bias, and then replaced them with 9.1V zener, and had tons. YMMV.
