SlewMaster Builds
Terry, were is this one pair PCB pdf?
Hi thimios,
I believe it is in the big thread. I'm not sure if Jason ever released the newest version in pdf. The one I etched has the outputs wide just like the normal Slewmaster. When I get to my computer I can post the foil for it. If you prefer I can send you the gerbers for this one or even the sprint file. This one can be easily be done single sided. The only important trace on top is a ground tying the two grounds together which can just be a wire.
Hi thimios,
Thanks Terry ,waiting for this!
I am attaching jpegs for the foil and silk mirror. I don't know how to produce pdf from sprint. If someone can tell me the process I can provide that.
Thanks Jeff and especially Jason for this great layout. I am attaching two pdf. one for the foil and one for the silk mirror for iron transfer.
As Jason said your will need to add a ground wire from G2 to the center terminal.
Edit; I forgot that Thimios uses photo-etch. I am also attaching a mirror foil for that.
Now that isn't the same as the Gerber am I correct? And the drill pattern is not what I am seeing on what you are calling the silk am I? Is there an actual file with just the location of the drill holes or some kind of cad file that gives the board house the drill pattern or how does that part work? Trying to figure out how to do this without having to make boards myself. I know the process and did photography work also when I was so much younger. I don't have the right type of printer or anything so the cost to go down that route doesn't make sense.
Hi Steven,
Yes, all the files the board house needs are in there. I believe the sprint file is there too but that shouldn't bother them. This is the "cheapskate" layout so it qualifies for the "proto-type" price with most of the board houses.
For those who don't wish to bother with that, I do have some extra boards. PM me if interested.
Blessings, Terry
Thanks Terry,
I saw your PM but didn't answer you yet. What you just put up will also contain the drill information then?
Now, blessing to you and Thank You,
Steven
There's a .drl file included for drilling. If you open it up in Notepad you can see XY locations and drill diameters. Some day they'll need to update to circle radius' and do away with the drill bits.
