CF-FET V2.0 front-end - going high-tech (SMD)
iirc you are to refrigerate solder paste, to extend its shelf life.
iaef, read the specs.
jeff, since you like your manual control, having a thermocouple is really nice to have. Another reason to build a good temp meter.
In the past. we used to use tape a number of thermocouples on a populated board and run it through the oven a few times to get the dwells,temp,soaks correct.
Another caution, popcorning, that is when the plastic package takes on too much moisture. this is why you get parts in a sealed bag with desiccant and a humidity indicator. if you leave parts out for extended periods of time in a humid environment and then process, you take the risk of damage or failure. you are supposed to store in temp/humidity env or pre-bake to drive out moisture. no risk if you hand solder. so there you go, some smt 101 for you today.
They don't say anything about refrigerating it on their packaging but mine just showed up with an ice pack in a cooler bag today. They've never done that before.
I'd like to do a proper oven controller again some day but with better mosfets next time.
It is actually pretty easy to modify most of those toaster ovens with a better controller. I've also done the same thing with room heaters when using them in a heater box or other equipment. A nice simple digital controller with a thermo-couple for a sensor and you can do whatever you want. You could go a step further and put a controller for the ramp rate up and down. About as basic as you could go with a PLC. But you don't need to go that far really.
It's a transparent "oily" jelly sort of paste with very narrow dispenser (pin hole) - I keep it without any covers and I'm sure it will work fine for some years. Very good as a flux by the way - clean, efficient, easy to apply...
Hi Valery,
This is the stuff I bought and used but it has no solder in it.
8341-10ML MG Chemicals | Mouser
I believer the stuff Jeff is using has solder in it and all you need to do is provide heat.
This smd is interesting but I wonder if I will ever do enough of it to justify the investment in all the equipment and special materials.
On the electrolytic cap issue, I have stripped a few commercial boards for parts and a lot of them are all smd except for the electrolytics, which were through hole. I'm not sure if that is because of cost.
Blessings, Terry
Hi Valery,
Blessings, Terry
There isn't much available in larger sizes of SMD caps. I think the risk of them popping in the oven likely has a lot to do with that.
As for the required investment, a toaster oven is cheaper than a good soldering iron and a syringe of solder is cheaper than a roll of Kester 44. The whole second inventory of parts and storage space needed for them is a big drawback though.
Yeah, I am starting to build a collection of smd parts already just from the little bit I've done. A while back I did a board for Dado's thermaltrak amp and he used 100V .1u smd caps for decoupling on the bottom of the boards. I liked that idea so I ordered 200 of them to use on other projects as well. I guess I will begin to add other values of caps and resistors to future orders until I can build a good base of parts. It is only the electrolytics that have me concerned.
Bessings, Terry
Bessings, Terry
Newark is a good place to stock up from. They have inventory reduction sales regularly. A 1206 1% resistor goes for $.003 each. 200 for under a buck is nice.
I hardly ever use smt ecaps. only use them when you are into mass production. hand stuffing components, on a large scale is expensive compared to pick n place. low leakage Nichicon UKL are my favourites.
you do not not have to invest very much $ at all to do successful smt work. I have yet to need a reflow oven. all i use is two irons, some 15mil glow-core no-clean solder and a 10x jewelers loup and that is about it. it is much faster than tht, no leads to form and cut. think of all that material waste on tht component leads. gee how many jumper wires do i need 🙂
I bought a sparkfun hot air machine to remove/reflow one "dfn" package.
using smt saves $ all around, because you reduce pcb area significantly!! Smaller,tighter layouts outperform ones that occupy larger areas. except for power, go smt!! one caveat, smt usually requires a multi-layer pcb.
P.S. found another t/c pcb, http://www.adafruit.com/products/269 with ardunio lib
Moving forward
Slowly but surely...
Ordered the steel shielding boxes for the front-end sections.
Heatsinks are in the workshop for precise drilling.
All the modules are soldered and tested.
I want to build i nicely 🙂
Hope to see it working soon 😉
