DC Servo MOSFET Amplifier
F120 with 22R add in positive rail.
Hi, here are a few photos of my second trial with the F120. I could not get it stable running.. A few times he was working, then again not, I have found no reason for it.
Does not matter. Because I no longer had patience to look for, I have a new attempt and started a new layout and a new prototype. Let's see. I will report.
regards Olaf
regards Olaf
I suggest F110 for new prototype.
Hello
I was simulating the F100 and I notice that after I simulate with 20K the sine wave does not stay smooth and has some sort of anomaly "not to be alarm" so I spend a few hours checking and it come that R22 4.7k I changed to 600R so now even if you go more than 20KHz it will continue to keep the output nice and clean, I mean this is my diy thinking I might be wrong, what you guys think ? 🙂
well I just re-drawing the F100 and add a trim pot and also a illustration of the original R22 4.7k to be placed there or trim pot 1K to do fine adjustment 🙂 also a re-drawing of the supply too please if some one see a mistake let me know I will leave the Sprint Layout 6 file here please only for diy to enjoy yourself guys 😀 I wandering if mister Terry already made it 🙄 ?
Juan
  • Apex F100.zip
    Apex F100.zip
Hello guys
I was checking again the R22 as 600 ohms is not save 😱 my mistake because it will drain more current it does reduce THD but not save so if I make it I will use R22 as 4.7K if later I want to experiment then I can do it
Juan
question, I was just making a larger version of the F100 and I was wandering if a coil can be add it to the circuit ? this layout is not test it yet just in case 🙂 I already simulated and respond really well, I think 😉 , I have to completed and check for errors here is the layout now "not tested"
one note the R34 can be adjusted to 1.5K and that will give about 45mA so reading one of the 0.22 5W resistors is about 10mV to be on the save area 🙂
I know is not like BJT but not to be abuse them jejejejejeje 😛 been mosfet
Juan
  • Apex F100 PLUS.pdf
    Apex F100 PLUS.pdf
Juan
Nice work, go to post #35.
