Building the ultimate NOS DAC using TDA1541A
I am in deep mental masturbation after seeing that recent step up transformer schematic 🙂
I´m working something out to try with the AD1862 current output. I have transformers with around 1:30 turns ratio (salvaged headphone output transformers from a broken reel to reel deck). What about driving a ds1882 45k ohms silicon pot directly? The 45k ohms impedance will be reflected as 45 ohms or so to the primary... no I/V resistor on the primary! May need a zobel on the primary, to flatten the impedance rise with frequency?
Roughly estimating, 1mA p-p output current from the dac, into 45 ohms reflected resistance, that´s 45mV p-p. Times 30 it will be around 1.3V p-p out of the secondary.
Looking forward to pass some square waves to see what comes out. Also check freq response, harmonic distortion (I think transformers give predominantly 3rd harmonic). I wish I had all the stuff and instruments at hand, should be fun!
I realize you probably want a filter to correct the non-oversampling rolloff, not really a tone control... sorry if a bit off topic.
Are you into computer audio? I have been upsampling to 88.2KHz and dithering to 16 bits with the windows 7 audio stack. With 88.2 you are down only 1dB or so at 20KHz. And windows upsampling works as well as, or better than JRiver upsampling for me.
While we´re at it, I am also using EqualizerAPO, which is a very powerful parametric EQ and also integrates into the windows audio stack. I previously used EQ in JRiver but I´m happier now! One of the reasons might be that I changed my method for correcting baffle step: I now cut the frequencies above Fc, instead of the opposite. It´s also important to have no pre-attenuation in the EqualizerAPO config file.
Dear John, guys,
I've been unable to find suitable source for the recommended Rohpoint resistors. I need 2.5K for the transimpedance amp and that means I can't make it as a DIY honeycomb...unless I put 5 in series(10 overall).
I hope someone can point me to some source for them.
Thanks in advance.
M.
Hi, I got them here:
https://www.rhopointcomponents.com/
https://www.rhopointcomponents.com/components/resistors/precision-through-hole.html
Rather high shipping costs though.
Dual Mono DAC
At last I had the time and energy to build -EC's- Dual Mono 1543 DAC.
After a couple of big mistakes (pin inversion on logic chips and lost of ground connection on on DAC chip) I finally succeded!
First impression is very good.
Unfortunatelly, I'm going on vacation so no more listening for a couple of weeks, but I couldn't go without finishing it. Probably will be the best (together the DIM4) and I will next make it DC coupled with John's idea.
More pictures on my Picasa album:
https://picasaweb.google.com/lh/photo/2dQJPRY1AcjmRChO38NlV9MTjNZETYmyPJy0liipFm0?feat=directlink
Thank you John!!!
M.
Max, photo number 2 is awsome ! Art piece about how it is looking : you found a new art movement : you should write a manifest and exposition with x 100 size instead the little pcb !
Like very much this hand made job ! looking diy and not out of the factory !
Thanks guys and sorry: I'm on the mountains without internet access and I don't have here the schematics, but I'm sure a quick search on the thread will succeed.
Yes dear Eldam, I am better than CNC machine tool, hehe. I used a "Dremel". Not ellegant but eficacious.
As usual, the important is the surroundings: excellent voltage regs, excellent voltage reference, excellent honeycomb I/V R.
