Vacuum Tube SPICE Models
Revised Ayumi GU50 Pentode Model
Fresh from the oven, get it while it's hot...😛
Code:
* Generic pentode model: GU50_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Thu Dec 23 17:30:30 2014
*               Plate
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT GU50_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+1
BM1   M1   0 V=(0.10436355*(URAMP(V(G2,K))+1e-10))**-0.94152046
BM2   M2   0 V=(0.61437126*(URAMP(V(GG)+URAMP(V(G2,K))/3.6950521)))**2.4415205
BP    P    0 V=0.0013346082*(URAMP(V(GG)+URAMP(V(G2,K))/6.0143635))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00086083603*V(M1)*V(M2)
BIG   IG   0 V=0.000667**408*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.952380952*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.047619048)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+11100)/(URAMP(V(G2,K))+11100)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0010136338*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0010136338*URAMP(V(A,K))**1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.1p
CGK   G1  K  8.4p
C12   G1  G2 5.6p
CAK   A   K  9.2p
.ENDS
Hmm. In Ayumi library which I have, there is a pure triode model. Works perfectly with triode sym:
* Generic triode model: 6GW8PT
* Version 3.10, Generated on Sat Mar 8 22:40:12 2008
* Plate
* | Grid
* | | Cathode
.SUBCKT 6GW8PT A G K
BGG GG 0 V=V(G,K)+0.84112562
BM1 M1 0 V=(0.01029284*(URAMP(V(A,K))+1e-10))**-0.37211195
BM2 M2 0 V=(0.80123414*(URAMP(V(GG)+URAMP(V(A,K))/19.311081)+1e-10))**1.872112
BP P 0 V=0.0043151181*(URAMP(V(GG)+URAMP(V(A,K))/24.10167)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0025686773*V(M1)*V(M2)
BIG IG 0 V=0.0021575591*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.002428883*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 4.2p
CGK G K 5.8p
CAK A K 7.6p
.ENDS
This model is the pentode as triode
see my sim
  • pcl86-amp.zip
    pcl86-amp.zip
I tried the triode model provided by jazbo8 however the anode voltage is very low phlilips has it on 120 volt is this a mistake in the philips drawing or is the model not oke
I think you are confusing the triode section of this tube with the pentode section strapped for triode operation. The two are not the same, and I think you are trying to use the triode strapped pentode model where you should be using the triode section model.
Try the attached triode section model: file 6GW8T.txt (rename to 6GW8T.inc), and match the name of the first triode (6GW8T). When I run the simulation, I get about 70.5 volts at the plate of the first triode.
Ray
I simulated a set of plate curves for this model and they compare quite well to the published curves for the triode section of this tube (see attached data sheet).
Plotting a manual load line also shows close agreement with the simulated results. I believe the problem is the cathode resistor R7. Are you sure this is supposed to be 15 ohms? That small value provides very little (negative) bias for the tube (only about 20 mV). A cathode resistor of 1.5k produces a much more normal operating point for this tube. With R7 = 1.5k, the tube operates with 117.8 volts on the plate at 920 uA, with a (negative) grid bias of 760 mV. With these values, I get a good clean output signal up to 4 volts peak (2 watts into 4 ohms). Of course, if you want more closed loop gain then you will also need to increase the value of feedback resistor R8.
Ray
There is nothing wrong with Philip's schematic, except the B+ voltages are wrong, the +2, +3, +7 most likely refer to nodes on the power supply and not the actual voltages. In any case, the Ayumi triode section model for the ECL86 does not do a good job of modeling the reverse grid current, which is needed for the grid leak bias used in the Philips schematic, to do so, you need to get or build a model that does. So for this particular circuit, the Ayumi model should not be used.
Thanks for that insight. I guess I was stuck on the idea that the input stage was intended to work like a typical common cathode gain stage with cathode bias. This makes sense now, although I personally wouldn't approach the design that way.
I have used this:
.SUBCKT 6N2P-EV 1 2 3 ; P G C (Triode)
* Modified from 12AX7A data by Arto Salo; CGP is 1.0 pF reduced, other parameters unchanged
* Verified with LT-Spice simulations and actual circuit
X1 1 2 3 TRIODE MU=100.26 EX=1.394 KG1=1651.8 KP=17950.75 KVB=524.4 VCT=0.50 RGI=2000 CCG=2.3p CGP=1.4p CCP=0.9p ;
.ENDS 6N2P-EV
On that note there was missing something
Code:
.ENDS 6N2P-EV
.SUBCKT TRIODE 1 2 3 ; A G C
E1  7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1  1 3 VALUE={(PWR(V(7,0),EX)+PWRS(V(7,0),EX))/KG1}
RCP 1 3 1G    ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1  2 3 {CCG}  ; CATHODE-GRID
C2  2 1 {CGP}  ; GRID=PLATE
C3  1 3 {CCP}  ; CATHODE-PLATE
D3  5 3 DX     ; FOR GRID CURRENT
R1  2 5 {RGI}  ; FOR GRID CURRENT
.ENDS           TRIODE
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N) ; diode used by the Triode, Pentode Beam Tetrode models
