The Eminence Beta CX-10 . What have you done with it lately ?
Lots of interesting information in this thread. Trying to figure out which way to go with four Beta 10CX's for a 7.1 surround system (the coaxials will be side/rear surrounds only).
I have to say, the APT-50 results looks pretty good, and a simple XO design is nice as it costs less to build.
Yea... it's an expensive XO.
here is build 1.1
I am happy 😀 (that may be a bit of an understatement)
Are your surrounds a lot closer to listening spot than three front speakers? If yes, they should be smaller i.e. less directional (read: use Beta-8CX or even smaller if you have for example Beta-12CX in front channels).
You can compensate the delay in the surround amp and virtually move surround further. Then all sounds from all speakers arrive at right time. BUT! You cannot make a speaker less directional with amp's adjustments. And if your surround speakers are too directive and close to you, you get more direct sound from them (comapred to room reflections) than from front channels.
My surrounds are definitely closer than the main L/C/R's. My main speakers are constant directivity speakers (JBL 15" 2226H woofer and B&C DE250 CD on a 90° H x 40° V bi-radial horn). The Beta-10CX's are significantly less directional so should be good on that end.
Is there an XO worked out for the ASD1001 and Beta 10cx?
Here is an Eminence article Using coaxial products for DIY monitors and home hi-fi applications | Eminence Speaker (the one from which some of the images in the link above were taken) that also states there is a commercially available Eminence Crossover.
Here it is: Crossover Detail | Eminence Speaker
and again here:
https://www.parts-express.com/eminence-pxb2-2k5cx-2-way-speaker-crossover-board-2500-hz--290-635
and again here:
I ended up getting the PSD2013S CD, it is supossed to be a drop in replacement for the 2002 but is several dB more sensitive (108.5 vs 105). I also ordered L-Pads to bring the levels down to that of the Beta 10-CX. Once dialed in will measure and replace with fixed resistors.
Would it help if we fill in the space around the voice coil top edge/cone to reduce the transition step with foam or something similar. Is that 'severe step' as bad on the real driver as in the drawing? How much does it audibly affect the performance ?
I am planning on a test of felt glued around the horn-cone transition for the 8" (maybe layered, maybe one thick piece, we'll see). The cabinet is assembled (and judged unacceptable without driver mods by me), but I can't promise it's coming very soon. Next six months is all I can promise, but probably in Jan I'll check it out.
I have a pair of CX10's that have not yet been put into action. It is supposed to work with a Kilomax18 on a small baffle. Have not yet tested them together though the 18 inch measured reasonably well in the room.
I wish I could finish it fast but things keep tripping up the project.
I'm very reluctant currently to remove the dust cover of the CX10. Better I try it out stock and then experiment with that later.
Do we get PU foaming agent in tubes ? Hope some PU foam experts can help us here.
Just found: http://www.amazon.com/s/ref=nb_sb_s...great+stuff+foam&sprefix=great+stuff+,aps,395
I plan on using the Beta 10-CX as a center channel speaker - please let mw know what you wind up with.
Beau
