The simplistic Salas low voltage shunt regulator
hi all,
maybe some you remember a discussion concerning semiconductor reliability relative to operating temperature
i sent e-mail to a few manufacturers for j111 jfet and fairchild responded to me with the attached.
maybe there is a chance it may contribute to the subject.
this link may also help to understand
http://www.hp.woodshot.com/hprfhelp/4_downld/products/xrs/at41511_r.pdf
BTW salas,
have you played with bsp129?
i built a b1 buffer and have no means to measure anything
but my ears tells me that it sounds fabulous in signature but maybe it is noisy...?
EDIT: buffer is between sound card and f4 ''sans'' jfet. BTW i did not compared it yet to complementary k170/j74....
also, f4 drives directly lowther pm6c or Axiom bookshelves without voltage gain stage
I will, I have it in mind, but I was doing other stuff, some pro speaker protos for bars and clubs. I expect them noisier than JFETs, that is for sure, also some degeneration resistors to keep them from drifting. Did they prove necessary in yours?
degen source resistor i did put.
did not tried without them but played with values from 10 to 2.5(used what i had)
but some russian guy on the web already built a commercial version( i think) for headphones with 1 ohm res.
also, sharing heatsink has fantastic tracking(used thermal paste)
