I speak to my dealer on a very constant basis. And I am always asking about different drivers. So I have asked on almost all the 18 Sound drivers before and have gotten prices from them. The 2500 cost about 380 dollars. The 9000 I ask about a while ago and they said they are no longer making that. I also asked about the 18ID which is a bit peaky but works. That is cheaper than the 9601 also.
9601 is around 720 and now the 2500 if considerably cheaper and offers almost the same performance. Huge bargain in my eyes.
agreed the 2500 looks prommesing.
my gues the price would be between the nd9300 and the nlw 9601.
didn't know about the 9000,they are still listed at the distrubuter.
maybe they are gona replace to a 9001 like the 9601, 9401.
Possibly.
You may still be able to buy the 9000. I couldnt is all. My dealer only orders me what I need. He doesnt have stock. He is a speaker OEM and just happens to be able to get parts for me.
Either way I am just happy I can get BC and 18 Sound for a decent price. Now only if I could get Faital Pro also.😀
fatial pro has xlimmit of 28mm p p for the 1600 and 30mm pp for the 1070.
compared to the 18sound and b&c not in the same balpark.🙁
Faital I would like to use their CD's and 12/15's. I like the 1460a from 18 Sound but do like lot of the Faital smaller CD's. I really only need a few drivers from Faital to work in a SH speaker is all. Anything bigger than a 15 I would stick with BC and 18 Sound.
EPA, faitals xmech is listed as one way. the xl1600 has 56mm p2p xmech, the 1070 has 60mm xmech (same as BCs offererings, the sw100 and the tbw100 at least).
tnx for this.🙂EPA, faitals xmech is listed as one way. the xl1600 has 56mm p2p xmech, the 1070 has 60mm xmech (same as BCs offererings, the sw100 and the tbw100 at least).
i was wondering about that, while i was reading your post in the other threat.
so fatials are not so bad afterall.
Keep in mind that these xmax values are the mechanical maximum before the driver gets damaged - NOT the usable, sane range... I don´t have the specs at hand right now, but the real geometrical XMAX is a more reliable comparison. Somewhere I have Klippel measuerements which give an even more realistic XMAX value on how much excursion is safe to use.SW115 has a 4.5" VC and 60mm P-P.
9601 has a 5.3" VC and 70mm P-P.
I am not assuming these are Xmax figures. I know these are Mechanical excursion levels. As I was saying before I just like the reassurance in knowing that I have more room for error on the 9601 in VC and excursion is all.
if you want to go for the xco1 cab ,your best bet wil be the p.audio elf,concidering your choices .
none of the eminence drivers wil fit the bil.
here is a comparison between the 2400 and the elf
Can you show input parameter page may be I can try to sim by myself for another Driver.
Br,
here you go
ID=34.20
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=9.32
S1=267.00
S2=460.00
Par=22.37
F12=0.00
S2=460.00
S3=1267.00
Par=219.00
F23=0.00
S3=1267.00
S4=2187.00
Par=42.00
F34=0.00
S4=2187.00
S5=2814.00
Par=20.32
F45=0.00
Sd=1225.00
Bl=25.60
Cms=1.07E-04
Rms=5.90
Mmd=168.61
Le=2.70
Re=5.00
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Path=0.0
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=xco1 18lw2400
ID=34.20
Ang=2.0 x Pi
Eg=2.83
Rg=0.00
Fta=9.32
S1=267.00
S2=460.00
Par=22.37
F12=0.00
S2=460.00
S3=1267.00
Par=219.00
F23=0.00
S3=1267.00
S4=2187.00
Par=42.00
F34=0.00
S4=2187.00
S5=2814.00
Par=20.32
F45=0.00
Sd=1225.00
Bl=25.60
Cms=1.07E-04
Rms=5.90
Mmd=168.61
Le=2.70
Re=5.00
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Path=0.0
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
hi
i have read the many pages here,but not all,first thank you all for efforts taken,,,
i got not the time now to learn hornresponse
so can tell me somebody please if the th 18 will work with a jbl 2241
i have four at home and they need new housings
i just finished a mth 30 tapped horn with a cheap thomann speaker and its crazy how loud it goes
so i want to get big tapped horns for my home system and best to use the jbl
or sell them and get proper drivers
thanx in advance
thanx in advance
They will "work", but their 7.62 Xmax is only about half of the B&C18SW115, so ultimate output would be 6 dB less, though they will be more sensitive, less power required for a given SPL.so can tell me somebody please if the th 18 will work with a jbl 2241
That said, output will be almost 6 db more than a ported box, four will rattle your house.
thank you for answering,i think i give it a try,only space for two th 18 🙂😀
but im not to much concerned with max vol,i hear loud but not to much
merci
merci
Im pretty sure this cabinet is geared towards pro audio use. A stack of Four would deff be for pro audio use.
But to each his own. If you need 135-140 db for a home listening system, go for it lol
🙂 so just to make you great guys laugh a little,and to show im not afraid of pro equipment
this is the top of my little party system
jbl 2123,2402,driven by bss omnidrive,3khz dividet,serious old amping,they are for the compromise to squeeze it in plastik jerry can very fun to listen and people are wondering how loud they are,box has compete inner outline with wood than foamed took me two weeks to build
have a great sunday all😀
The "2402" was probably stolen from an ultrasonic traffic control station, and contains a 2405 diaphragm, which in the 2402 housing makes for a rising response peaking around 21,000 Hz.🙂
have a great sunday all😀🙂
LMAO!
- Subwoofers
- TH-18 Flat to 35hz! (Xoc1's design)
