Hiraga "Le Monstre"
Resistor in CRC (2W 1 om) will blow up.
"We have decided to go ahead with NJW transistors because of cost and easy availability locally." And?.. In my shop too much TIP35C+TIP36C from ST, but I use ON Semi MJL on 4 MHz. 😀
With 30 MHz AMP will be unstable, look for MJW21192+91 as example, or another 4 MHz ON Semi.
P=IIR, if bias=1A and no dual mono and R=1 om, then (1A+1A)^2*1 om=4W.:flame::wave::RIP:😀😱
Should I change it to 20W😱?
Sachin
You don't even need to put resistors, simply install an inductor.
If you can't then a CRC should work but will be noisier unless you add TONS of filtering capacitors.
A CLC filter has a lot more ripple reduction than a CRC one without losing too much voltage and generating too much heat. To further lower the noise floor, simply use a CLC filter, rather than a CRC filter circuit.
Try a CRC and if your set-up is a bit noisy replace those resistors by an inductor.
BR,
Eric
Here is some measurements taken on my le monstre,
note the bias is deliberetly set low to get the steep increase of THD with output power like one would get with a 2A3 / 300B amp.
I did have a photo of the distortion waveform in realtime (captured with a HP 339A showing it to look rather similar to a pentod driven 300B, indicating not only the amplitudes of the distortion components shows similarity but also their phase relations.
And what about the sound Le Monstre 8W vs. WE300B?🙂
