Building the ultimate NOS DAC using TDA1541A
WS (Word Select) is for I2S, LE (Latch Enable) is for offset binary format. Their function is different: WS controls left/right data input, it has 50% duty cycle. LE controls simultaneous conversion of L and R channel, it is a short pulse.
Yes I just want ed to point the same thing...
How LE pulse should be after stopped sys clk burst?
and how long it should be last 1 sys clk?
is it enough to be 4 pulses (2 word bits) to 16bit length, or larger silence?
And does the LR data bus should be splitted into LL and RR for literarry simultaneous or coud be one after another?
sorry for poluting the topic with Qs about different dac chip model...
re #5127
Some people might be a bit confused by Niamex's use of the 68R I/V resistor connected directly to the output pins of the 1541A dac chip
Just a remark - in my setup the current travels from the chip to the grid of a tube and the 68R is just there - between the grid's pin and the heater,s ground - it was recommended somewhere in the thread.
All the current goes through the 68Ohm resistor, as the grid dosent draw any current.
This is the I/V resistor.. depending on how you bias the tube (say -0.13V) you might get some grid current but with such low value of 'grid leak' the bias offset will be minimal and also I'm lead to believe quite linear in its effect/non-effect.
Of course, the lower value I/V resistor, the more gain is required.. and S/N factor becomes an issue. Consider d3A which has (apparently) the noise equivalent of a 70ohm resistor, mu of 77 and Rp 2k. 33-47R I/V seems about right. This is what I have playing right know. CCS loaded, minimal bias.. and it very good, to me, with my biases and issues.
The added bonus is that you can use 6688 which is a $5 10khr SQ Euro tube, E280F also but not $5. You need to be careful with oscillations. I can give some tips on that if you think it will help.
Shane
Unfortunately I am not educated enough to understand this, will be thankful for a pm tutorial, the tube is Bendix 6385.
Ignat
Its ok.
What I can say is that the tube is essentially a 2C51. I've used WE396A the same.
Not so high Gm, you'll be fine..
My Take - others will disagree.. DC heat the tube, schottky bridge CM 10R then 33kuF to LT1085A as CCS regulator.
Load the tube with a CCS try 5mA to 8mA, take output from 'mu' or upper resistor of lower ring of two transistors for Zout 1/Gm or there abouts - 2.2uF coupling cap to keep phase shift negligible at low frequencies and also keep output impedance (XC) low at the same.
Mu is like a 6922, 33 or so.. bias with tda1541A current through 39ohm, grid leak.. add 22ohm to each cathode.. use one triode per section D/A output left/right. No bypasses on cathode.
Add 220 carbon composite between I/V resistor and series grid. For good measure add 50R carbon composite between CCS plate load and plate.
You could bypass cathode resistors 22ohm with 0.001uF poly but with Gm being low enough, you'd be likely ok.
Thats a nice tube.. I'd swap for WE396A any day.
Use a tube rectifier with a heater for slow ramp up.. let A supply heaters come up first.
If you can, choke input (meeting critical inductance) to 100uF then LC split 10H to 55uF or such to each branch and you're laughing. Bleed 10mA across each final filter to help lower noise… and on one branch form a voltage divider to raise the heater (faux) centre tap to +35VDC or so, bypass with 2 to 10uF.
You wont look back..
.. Yeah ok you will. but it'll be fun.
Shane
Its ok.
Shane
Hi Shane,
Please share your schematics.
Goh
Hi Goh,
As requested.
This one is for d3A but 6688 E180F drops right in (e280F also).
You could probably reduce cathode resistor to 22ohms, perhaps even 10 ohms.. easy enough to play around with. The main idea is using the -2mA current offset from the 1541A to help minimally bias the tube, credit to Thorsten for the idea. The removal of the CCS injection scheme (to null for 0V at the 1541A output) probably also had some positive impact.
No doubt there are better circuits out there.. but this one is quiet, has good drive and low output impedance and was fun to build ( I cant solder solid state bits very well)
Shane
Hi JOSI1,
could you please explain in a few words how to create the 3 supply voltages for the TDA1541A (+5V, -5V, -15V) from a single 24V supply.
You need 3 shunt regulators, two 5V shunt regulators and one 10V shunt regulator.
Connect these as follows:
+24V -> current limiting resistor or CCS -> 5V shunt reg -> 5V shunt reg -> 10V shunt reg -> 0V.
+5V present between CCS / resistor and the plus of the 5V shunt reg #1.
GND present between the minus of 5V shunt reg #1 and the plus of 5V shunt reg #2.
-5V present between the minus of 5V shunt reg #2 and the plus of the 10V shunt reg.
-15V present between the minus of the 10V shunt reg and 0V of the 24V supply.
TDA1541A draws following current from the supply voltages:
+5V, 27 … 40mA
-5V, 37 … 50mA
-15V, 25 … 35mA.
So a bias current of 100mA should be sufficient and holds some reserve for powering other circuits as well.
Hello John,
when cascading the 3 shunt regs isn't there some risk of crosstalk between the 3 supply voltages in case of fluctuations of the load currents (although they might be very small) or in case of switching noise on one of the supply voltages.
Hi Shane,
Thanks for sharing, post #5152.
There is a 39 ohm resistor, will the dac see low impedance?
I am presently using 33 ohm and 1k into the grid of 12AU7
in SRPP topology. The noise level is a bit on the high side.
You may wish to help me improve.
Goh
-ecdesigns-; The analogue circuit was next. I wanted to use passive I/V conversion with the highest possible output signal (while keeping distortion low). I ended up using a 140 Ohm I/V resistor (between TDA1541A output and GND). Without further measures this will result in massive distortion as the output signal clips on the lower side. This can be solved by injecting a bias current (on the DAC output pin). I used a 1 K Ohm resistor in series with a hybrid choke connected to +5V. This way one can squeeze around 550mVpp directly out of the TDA1541A while maintaining low distortion. Then it's quite easy to amplify this signal to a suitable level to drive a power amp. [/QUOTE said:
Hi John,
I happened to see your post may be too late so please suggest do you still recommend that kind of injection /for the time-being I have no decoupling caps and just 6K8 resistors as you suggested/
Thanks,
Ignat
Hi John,
Thanks,
Ignat
Where did you find that quote?
Which post #?
John is talking about bias injection to the analog output of the TDA1541a , not the DEM circuit you are referring to. (6K8 resistor is from DEM to +5V)
Koldby
Hi niamex,
TDA1541A output compliance (absolute maximum rating!) equals +25mV and -25mV.
Output current varies between (almost) 0 and -4mA (only goes negative).
Without signal output current equals -2mA.
When using a passive I/V resistor between output and GND without a +2mA bias current (to compensate for the -2mA bias current of the TDA1541A) the voltage can only go negative. Voltage swings above 25mVpp will now already exceed output compliance of -25mV. Absolute maximum value for I/V resistor would be 0.025 / 0.004 = 6.25 Ohms.
When using +2mA bias current, voltage swing is extended to +25mV and -25mV (instead of 0mV and -50mV) as signal swings around, not below 0V. Provided suitable CCS is used, this will always lead to lower distortion with given output signal swing. Absolute maximum value for I/V resistor now equals 0.05 / 0.004 = 12.5 Ohms.
Exceeding output compliance not only leads to increased distortion (non-linear response), it also leads to increased TDA1541A induced deterministic jitter.
TDA1541A performs best by far with (almost) zero ac on its outputs.
Leaving out the 14 filter caps on the TDA1541A will lead to clearly measurable switching spikes on the TDA1541A output. This may or may not be a problem, depending on desired performance.
When leaving out the filter caps, make sure f DEM is at least 4 times higher than fs (sample rate). So for 44.1 KHz NOS this translates to 176.4 KHz f DEM and for 44.1 KHz with 4 times oversampling (SAA7220) this translates to 705.6 KHz f DEM.
