QUAD 909 Clone
My copy of the circuit doesn't have these discrepancies.
Hi Mooly, yes the Quads use enequal rails which is achieved by the vitual ground in the driver stages.
The output stage just uses a virtual ground between two series caps.
The 606 and 909 are virtually identical.
I would expect all the common "grounds" to be connected in such a way that the main smoothing cap zero volts is common to the active virtual ground.
But maybe not.
I couldn't get a 82V transformer off the shelf so I've got a 80V 800VA.
if you really need to make adjustments to the supply rail voltages you could add half a dozen turns to the secondary, or maybe two sets of 6 turns so you can adjust in steps.
Then you can add a few dozen turns to the primary to reduce quiescent current draw and wasteful heating of the transformer. This cuts down saturation, when mains voltage is high.
I've never made a study of the Quads tbh but this virtual ground arrangement seems to dictate that the two channels should be kept essentially separate and that will be why two secondaries are shown on this series of amps.
I've ordered two anyway, I've just got to wait 55.46666 (LOL :-( ) days for the second one to arrive. I thought Dad's Aleph 4 was muscle busting but this is going to be heavy.
But maybe not.if you really need to make adjustments to the supply rail voltages you could add half a dozen turns to the secondary, or maybe two sets of 6 turns so you can adjust in steps.
It's an odd arrangement, 0V seems to float around a bit. 82V vs 80V seems to be the only difference between the 606, 707 and 909, the rail voltages are slightly different.
To me it just seems odd that 0V is controlled by two such small transistors.
I can understand that is how it seems but the 0v line isn't controlled in that sense. It is a fixed point in the circuit that has been designated 0v and to which all other points are referred. This 0v line has no ability to have current sourced or sunk into it beyond a few milliamps... but it doesn't need to.
I bought two dozen MJ15003s from RS a couple of month ago when they reduced the price attractively. Testing at 1 amp their gain range covered 70 to 107 with almost the same number in each decade (with a happy peak at 90-99).
24 is hardly a significant sample but may hint at the RS population.
