Pioneer SX-1080, after re-cap problem w. center voltage & idle current
Controlling values for Q#, A4 against same, unused:
KSC3503: new NPN: Q3,Q4
e-b 24 MOhm
c-b 16 MOhm
Q3:
e-b 22 MOhm
c-b 15 MOhm
Q4:
e-b 22 MOhm
c-b 16 MOhm
Took a short test with FM and headphones:
Volume off (min)
FM tuned to god signal with stereo.
Veak and flat, but clear music in right channel.
One click up on the volume gives natural sound in left ch. right remains the same.
Turning balance leaves right ch unaffected, left reacts as expected.
That was suppsed to be:
Controlling values for Q3, Q4 against same, unused:
New readings
Hi
I hope you haven't spent too much time on the next step, because I discovered I had left 2 resistors up in one end (R7,R8) :headbash:
That said I did read the voltages listed on the schematic:
HTML:
                        Read	Spec
intersect. C4,C5,R6:	-0.6	(+0.6)
intersect. Q1,R3,R33:	-0.02	(0.0)
Q4c			-7<-	(+3)
Q4b-R8			+60.6	(-58.2)
Q3b-R7			+60.56	(-58.2)
Q3c			+1.0	(-1.2)
Q5c			+0.83	(+1.2)
Note polarity is reversed 😕
Checking center voltage.
Positive lead to pin 10, negative lead to chassis
Initial reading at -0.85 mV
Adjusting VR2 gives very small changes: 1 turn ~ 0.02V
Hi
Please disregard #84 - polarity is correct - I had swapped the probes :blush:.
HTML:
                        Read	Spec
intersect. C4,C5,R6:	+0.6	(+0.6)
intersect. Q1,R3,R33:	+0.02	(0.0)
Q4c:
Starting at +9V drop to +6.5	(+3)
Q4b-R8			-60.6	(-58.2)
Q3b-R7			-60.56	(-58.2)
Q3c			-1.0	(-1.2)
Q5c			-0.83	(+1.2)
HTML:
Pin readings:[HTML]
1	-62.3	(-60)
4	+23.4	(+23)
5	-23.2	(-23)
8	+61.9	(+60)
12	+61.9	(+62)
22	-61.9	(-62)
Hi
HTML:
                        Read	Spec
Q4c:
Q3c			-1.0	(-1.2)
Q5c,Q6b			+0.8	(+1.2)
Replaced Q4 with new spare - no difference for Q4c.
HTML:
Pin readings:[HTML]
1	-62.3	(-60)
4	+23.4	(+23)
5	-23.2	(-23)
8	+61.9	(+60)
12	+61.9	(+62)
22	-61.9	(-62)
Still struggling with power amp
Transistors Q1 (2 of them in the combo sub) Q2, Q6, Q7, Q8 have been pulled, and all read between 0.6 - 0.7 V e-b and c-b.
Q3, Q4 and Q5 have been left un-tested since they just have been replaced with new ones.
Q1 is now the combo of 2 KSA922.
D2 is replaced (was new from rebuild) again just in case, but with no effect.
I took a glance at the power meters, and when the relay clicks in right ch meter jumps to -27 db, and stays there, regard less if no function button is depressed (all out) or if any one is.
Just a symptom that right ch is srewed up, I guess.
Please see all the voltage readings on attached image.
:worried:
OK, cool.
Can you please check the big output transistors (the ones we keep unplugged so far) with the ohm-meter, the same way you did it before with the other transistors?
We need to make sure none of them is shorted.
Also, please measure the voltage, putting the leads between the pins 15 and 20
OK, cool.
But they were never connected again after they were tested and unplugged, and they aren't part of the present circuit (unplugged) ?
Will do...
