DAC-END R (ES9018) full assembled board - version 2
Hi all,
after ordering the DAC with amanero module i would prefer to fit my pi directly to the DAC via the Input where the amanero is plugged.
So far i understand the amanero module is also connected via i2s. So this must be possible.
Does anybody here know whether i am right to think so. One should only know the right pins to connect to.
Greetings
Juergen
Hi all,
Greetings
Juergen
I personally wouldn't use a Pi, because it hasn't got a descent onboard clock, but you are right. It is possible to use a Pi instead of the Amanero. You could even connect both if you use a multiplexer like TP's OTTO, but you need to provide some way to switch between the Amanero an Pi yourself (which is no rocket science).
Check this thread:
http://www.diyaudio.com/forums/twisted-pear/250583-building-open-embedded-audio-applicance.html
I doing it with a Doede dac, but many others have done it with ess dacs, including the originator of the open appliance thread above.
Also see here:
http://www.diyaudio.com/forums/pc-b...o-audiophile-audio-player-26.html#post3851652
Hi guys,
thank you very much for the comments.
Until now i use a pi with the hifiberry i2s DAC.
It plays quite nice and the hires stuff is no problem. The resolution is very good.
But the trebles are too soft and the soundstage not deep.
In these criteria my Mephisto/Audionote DAC2 is much better, nevertheless it misses some details.
Because the pi is not good for more than 24/96 res and usb out, I thought it would be better not to go over the amanero and stress the pi.
@Corpius: it would be really cool to use both because outputting of all my sources over the new DAC in unique manner would be the best.
@linuxfan: thank you for the pin assignement.
@palmito: thanks for the links. I used first Raspyfi, now i tried Runeaudio with self compiled kernel for i2s support for my own. Until now it runs fine for two months up without problem.
Greets
Juergen
Add me to the waiting list. Is it known when approx. new lot will be available?
1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
Amanero board, Raspberry Pi B ordered...
Working on the micro-controller interface with touch OLED...
PCB for modified FLEA (VCC, VDD, AVCC) ordered...
LiFePO4 BMS with charger designed...
Designing enclosure...
Here are the first pictures of the DAC 32 v2 invite you to view photos!
thank you
Here is an image of the internal components in the DAC 32 V2
And more
Beautiful Job!!!!
Greetings Quanghao,
Absolutely stunning! 😀
I will be very proud to have this component in my system.
Thank you for your outstanding work on this project!
Kind regards,
Steve
