DAC-END R (ES9018) full assembled board - version 2
1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7.flocchini options (1 + 4 + 5 (DAC + amanero + transformer))
Waiting list:
3. Abszero!
5. smokingdog
7. flocchini options (1 + 4 + 5 (DAC + amanero + transformer))
8. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
3. Abszero!
5. smokingdog
8. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis) 9. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
Waiting list
3. Abszero!
5. smokingdog
10. fm-maniac - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
Hi guys
What do I need to do to be in the group buy for the new DAC?
Should I only put my name and the options I wish on the list and then post this list here or do I need to contact quanghao or Andrea separately?
Kind Regards and enjoy your day
Phil
Hi Phil
You should just add your requirements to the list. Quanghao is probably very busy with the existing GB right now. I started the GB 3 list in the hope that Quanghao could be persuaded to have another run for those that managed to miss the last 2.
Regards,
I also hope another run will take place. Big respect to Andrea+Quanghao!
Can I ask if the I/V output still contains headphone output? I couldn't find it on the pictures.
Also, could the transformer output PCB be used directly with Jensen JT-11-EMCF or BMCF (http://www.jensen-transformers.com/datashts/11bmcf.pdf). The BMCF has ridiculously good parameters and costs half the price of LL1684. I'm not sure if the size would fit though.
DAC VER2 measurements
Hi all
I have have made and attached some measurements on the DAC2 Version.
All looks pretty good and im very impressed by the high quality from Huang Hao and Andrea.!!!
Thank you guys for this making this DAc in so high quality !!
Br
Caad
you can use Jensen JT-11-EMCF for PCB LL1684, because there is no space for it pcb.
thanks
1) DAC module assembled and tested with all components
I spent a lot of time, to complete the DAC version v2 and
The following is the number one choice. I have a new change of control, aluminum silver, and the price is increased. I very much hope: this did not make you sad, and you also sympathize with me
I am deeply grateful to you, and all your trust!
The other part of the information I will continue tomorrow
Quanghao
