DAC-END R (ES9018) full assembled board - version 2
1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7. flocchini options (1+3+4+5 (DAC +chassis + amanero + transformer))
8. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
9. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
10. fm-maniac - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
11. bamarek - option 6 - complete assembled DAC with LL1684
12. Sugden - (option 9)Complete assembled DAC with Lundahl LL1684 output stage
13. Nicos - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
Hello,
I am interrestedby this amzing dac.
I have a question.
I want to make audiophile network music player to play DSD and FlAC file.
I want to connect udoo mini pc, what is best solution to play DSD files:
- udoo with IS directly to the dac
- udoo directly to amanero USB on DAC.
Thank you for your responses.
Test setup for testing the DAC Ver2
Hi all
Here is a look in to the lab where im testing the DAC Ver2...
The New DCD modules is tested in the prototype chassis.
Br
Caad
Hello,
I have a question.
Hi , you connect computer to AMANERO USB one the DAC, and play music
thanks
Waiting list
3. Abszero!
5. smokingdog
10. audiomusica - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
Hi Quanghao,
I am interested in a full kit dac (1,2,3,4,5), but I want to have the 3 different output stages you have (I want to test it with different set ups), opamp (old one), MOSFET I/v (this is option 2) and transformers (LL1684). I would like to assemble by my own.
Would you mind to let me know how much it will be?
Thank you!
Waiting list
3. Abszero!
5. smokingdog
14. mjensen - (option 9) - complete assembled DAC with Lundahl LL1684 output stage
Hi Quanghao,
Thank you!
Why also op-amp ? the real comparison is between the LL1684 and the new solid state output module.
Because I have some other dacs that has op-amp outputs and I want to compare it, same as I want to check with my hifi headsets I have etc. it is more a personal question I have than a specific what is the best out put section on for this Dac 🙂
