1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7. flocchini options (1+3+4+5 (DAC +chassis + amanero + transformer))
8. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
9. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
10. fm-maniac - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
11. bamarek - option 6 - complete assembled DAC with LL1684
12. Sugden - (option 9)Complete assembled DAC with Lundahl LL1684 output stage
13. Nicos - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
3. Abszero!
5. smokingdog
Hello,
I am interrestedby this amzing dac.
I have a question.
I want to make audiophile network music player to play DSD and FlAC file.
I want to connect udoo mini pc, what is best solution to play DSD files:
- udoo with IS directly to the dac
- udoo directly to amanero USB on DAC.
Thank you for your responses.
I have a question.
Hi caad, the output level of the DcD is done by setting the I/V resistance for maximum gain?
What is the VA of your trasformers?
Claudio
Claudio
Hello,
I am interrested by this amazing dac.
I have a question.
Claudio
Hi
When making measurements, The DCD modules are set by the jumpers to Max output AND volume setting to 0dB attenuation.
The trafos are no special trafos . You will need 18V AC / 0,9-1A trafos.
Br
Caad
ok, no problem !Hello quanghao
i do not need the remote in aluminium because i will not use it very much. Is it possible to get it as planned until now?
Greetings
Juergen
please waite me test all finis, i will sent to you.
thanks
Hello,
I have a question.
Hi , you connect computer to AMANERO USB one the DAC, and play music
thanks
Hi all,
any suggestions for a good CD-transport? Maybe even DIY? Also able to track SACD.
PeterD
PeterD
Waiting list
3. Abszero!
5. smokingdog
10. audiomusica - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
3. Abszero!
5. smokingdog
Guanghao
Do we do anything at this stage or we wait for a minimum number of orders to be collected?
Aluminum remote price = $40
Daniel,
New aluminum remote is $40.
See info here:
http://www.diyaudio.com/forums/quan...sembled-board-version-2-a-62.html#post3905918
Steve
Daniel,
See info here:
Steve
Hi Quanghao,
I am interested in a full kit dac (1,2,3,4,5), but I want to have the 3 different output stages you have (I want to test it with different set ups), opamp (old one), MOSFET I/v (this is option 2) and transformers (LL1684). I would like to assemble by my own.
Would you mind to let me know how much it will be?
Thank you!
Thank you!
Waiting list
3. Abszero!
5. smokingdog
14. mjensen - (option 9) - complete assembled DAC with Lundahl LL1684 output stage
3. Abszero!
5. smokingdog
Hi Quanghao,
Thank you!
Why also op-amp ? the real comparison is between the LL1684 and the new solid state output module.
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
