JG´s Nobrainer and Nobrainer Discrete
Keep registering lower current in the lower half... is it normal ?
Plot I(R17)-I(R16) and all will be revealed 🙂 also DO NOT USE THAT HIGH A BIAS (it's not improving anything (except global warming 🙂)). What you see is the non linearity of the OPS (output stage) due to class A operation (but not in a positive way) the + side compensates for the - side (so to say) and the other way around. The sum (or difference) of the currents shows the signal (not each of the currents).
