Building a Pearl 2
I'm in the process of ordering all my parts. I have questions on a couple parts.
According to both DigiKey and Mouser the LM7924CT is an obsolete part. Can I use the KA7924TU. If so should I then use the KA7824ETU as the +24 regulator.
I'm ordering all RN60D resistors but the 499R (R9, R28) are out of stock. Could I use 500R in it's place.
The build is on!
I got all my parts in from Mouser today. (Merry Christmas to me).
I received my power supply kit from ChipAmp.com and transformer from Antek (AS0522). I assembled them and am getting a little over +-30V.
Today I assembled the power/regulation area on the P2 board. Tomorrow I'll connect it to the ChipAmp supply board and see what I get.
I ordered 2 Galaxy 388 Chassis from the diyAudio store and they have shipped.
Time for bed🙂
testing power
Tested the regulation section of the board this morning.
First picture shows unregulated supply hook up.
Second picture shows regulated voltage.
Third picture just shows board and meters.
Fourth picture is unregulated voltage.
got that thanks
😀 Hi 6L6--Thank you once more sir, that will save some room then!, but- I wont push my luck and put it in a modu 5u case for the "ultimate F5 Integrated"-- (unless you know better?- I like the idea but to much transformer hum abounds--any one tried that??)
cheers
Johnny
Finally swapped out the Rega Bias 2 cartridge with a Denon DL-110 I had picked up awhile back. Big upgrade on my system with the Pearl 2! Like taking cotton out of my ears. Dramatic decrease in surface noise as well. Very happy camper!
Getting Close
My Galaxy 388 chassis came in (very nice).
The boards are populated:
I left R20, C7, C15, and C22 out.
I jumped R15
I have all the parts needed to finish: AC entry/fuse module, RCAs, umbilical cord, and TT grounding post.
I've mounted the PCBs in the main chassis.
I just need to find someone to machine the back panel.
And then wire it up.
