Vacuum Tube SPICE Models
Philips 18040 Model
I used 18046's triode data and fudged it to fit 18040's curves, and the SPICE model is shown below, please test it. 18040's datasheet indicates that the maximum Vg1 is -1.3V, perhaps that's why the 0V and -1V curves were not fully visible.
Code:
* Generic pentode model: 18040_AN
* Copyright 2003-2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sun Dec 22 12:36:57 2013
*                Plate
*                | Screen Grid
*                | |  Control Grid
*                | |  |  Cathode
.SUBCKT 18040_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+-0.083801857
BM1   M1   0 V=(0.0081798859*(LIMIT(V(G2,K),0,1e16)+1e-10))**-0.49067171
BM2   M2   0 V=(0.7535145*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/30.133122,0,1e16)))**1.9906717
BP    P    0 V=0.0067112265*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/39.990102,0,1e16))**1.5
BIK   IK   0 V=IF(V(GG)>0,1,0)*V(P)+(1-IF(V(GG)>0,1,0))*0.003878634*V(M1)*V(M2)
BIG   IG   0 V=0.0033556133*LIMIT(V(G1,K),0,1e16)**1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.78812548*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))**1.5+0.21187452)
BIK3  IK3  0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+15630)/(LIMIT(V(G2,K),0,1e16)+15630)
BIK4  IK4  0 V=V(IK3)-LIMIT(V(IK3)-(0.0036089138*(LIMIT(V(A,K),0,1e16)+LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16))**1.5),0,1e16)
BIP   IP   0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.0036089138*LIMIT(V(A,K),0,1e16)**1.5),0,1e16),0,1e16)
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=LIMIT(V(IK4,IP),0,1e16)
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.02p
CGK   G1  K  9p
C12   G1  G2 6p
CAK   A   K  7.5p
.ENDS
When I had all the answers, they changed me the questions... 😀
Ayumi Nakabayashi models are very accurate, I could check through the average plate characteristic curves, and average transfer caracteristics curves.
However, in simulations, distortion is 10 dB greater than with Norman Koren models.
To remove doubt, I simulated the circuit proposed by Morgan Jones, again with Norman Koren models the results are consistent (+ - 1 dB) while with Ayumi Nakabayashi models, distortion is always about 10 dB higher.
The million dollar question is: if the valves are defined by their curves, why with more precise curves less accurate results are obtained?
<snip>
Did you actually measure any of the tubes in the circuit you based the simulations on?
I typically measure at least 10dB more distortion in an actual circuit than in a simulation using the Koren models. (My latest phono stage design shows this clearly) Could it be that the Ayumi models are getting closer to the truth?
The tools I use to generate models are all based on the Koren equations. (paint_kip, paint_kit, and the uTracer alternate gui) Eventually I will learn the Ayumi method and see how that works.
Hi Kevin
Good to see you around here !
I only have an old scope and a 555 based square wave generator, LTSpice is my only blind cane. 🙁
I compared the results from Morgan Jones Valve Amplifiers fourth edition, p.201, 202, and with Koren model 2nd is about -52 dB, close to experimental result, -51dB, for a 6SN7.
Same simulation with Nakabayashi model yields about -41 dB.
BTW, the D3A (triode connected) model is one of yours, and does work fine. 🙂
Does anyone have actual measurement data on the above circuit that we can use as a benchmark? Unfortunately, I don't have the D3A, otherwise, I would breadboard the circuit and test it.
