Aleph J illustrated build guide
Nelson says to use the slow in Class-A PSU. I like them just for the convenience factor.
As for your caps, use whichever fit better. I personally would save the 50V caps for a project that needs the higher voltage rating. Don't forget the inrush suppressor, those are all big caps.
We had this conversation with you, 6L6 🙂. I just took and tried ultrafast... I can tell you I liked the better, for my taste they give a quieter background 🙂. So I think I will be using them, at least for a while 🙂
Why do you say overkill of capacitance? I used 0.4f per channel on f5Tv2 and all my FW amps are using 0.4f for a mono PSU setup... As one wise man told me: Whatever makes you sleep better, right ZM? 🙂
cos 6 x 150.000 µF is 0.9 F and you'll agree that is quite more than 0.4 :smash:
I'm planning to use 6x 150.000uf/35v per channel (monoblock)
PKI, more isn't always better. Did you make some measurements or at least use
PSU designer?
Believe me, I love big PSUs. I have 250 mF each channel on my AJ. That definitely
makes no poor PSU (it's also CRCLC with a shielded 500 VA toroidal). Problems raise
with capacitance though.
BTW, for diodes read this: http://www.diyaudio.com/forums/solid-state/12539-high-speed-diodes.html
Thank you all for great answer.
As i read from pass article :
For the caps :
Bigger and heavier is better. Bigger transformers and wires load down less. Big capacitors hold more charge.
Is there such a thing as too big? Certainly there are diminishing returns as we get bigger. When a transformer is delivering 1 watt to a preamp circuit, going from a thousand watt rating to two kilowatts isn't going to buy you much improvement. This consideration is not much of a deterrent to the average audiophile, however.
I liked the word "diminishing return"
And i agree with it, value for money.
Big is better, but not equal for the value we get.
As for me, I am not buying more caps. I use those big can caps just because I have it before.
For the rectifiers:
Yeah, sure, rectifiers are important, after all, the AC has to get converted to DC, but I don't like the fast recovery types that some audiophiles have raved about. Fast recovery means that they withstand many amps and volts in a tenth of a few nano-seconds, something we don't see very often on the old 60 Hz AC line. They are essential element in switching power supplies, but for regular "linear" power supplies, I much prefer SLOW diodes, and we create them by placing small capacitor circuits across the diodes, which greatly reduces radiated noise.
This is very helpfull information.
But still, no explanation for the impact to audible.
Maybe it is measurement in tools vs audible(in ear)
PSU designer?
Oh, I am ashamed and humiliated now! 🙂
I know I know. I always think of a music as of modulated power voltage. I know about importance of measurement. Unfortunately, at the moment I do not have much test equipment for proper measurements.
Thanks for the link, I will read it!
PKI, search for PSUD2 (PSU designer) - it's freeware !! Results are often stunning. 🙂
For the caps :
For the rectifiers:
This NP article is a buying guide for commercial equipent, not a design guide.
This make a huge difference.
The truth is, most commercial equipment comes with moderate PSU capability.
I just think if caps are reservoir (and we have a very big reservoir) then we need a better and faster tools to get the water filling up the reservoir faster.
But I am not sure rectifiers have Related to this problem.
The main problem besides cost is the vast inrush current. For 0.9 F (900.000 µF)
you need tough rectifier diodes (+ heatsinks) and a soft start circuit to avoid
blowing fuses and rectifier damage.
use them all
CLC or CRC
smaller then bigger
So if I have an equal number of 22,000uF and 10,000uF caps for a CRC, it's best to use (2 x 10kuF) -> (R) -> (2 x 22kuF)? (For an aleph-j)
I played around with the duncan amps tool and tried 3 permutations. I thought it was marginally better to have the high caps first. But I'm far from sure I looked at it correctly and I'm sure zen mod is smarter than a piece of software. 😀
every software is just smart as man using it
that includes Mighty ZM too , who is pretty dumb regarding any software :rofl:
however - look at voltage and current in xformer and rectifier , not just on end of PSU
If I tell you that my next (proper ) amp will have current through xformer as attached , while needing 33Vac secs for 22Vdc@2A2 , without any sort of active regulation , what you'll think ?
:clown:
:clown:
I hate tests, my head hurts, this is stretching my abilities which is good. Looks like if you were to invert the negative part, you'd end up with a slightly asymmetric sine wave that has a +2 DC offset. Am I on the right track? Why is the Vdc lower than the Vac - I thought it should be 1.4 higher before losses.
Tried to play with PSUD2, need your suggestion which one is favourable for dual mono configuration, pro & cons analysis will be much appreciated:
- CLC using 2x18V 225VA
- LCRC using 2x25V 500VA
for C6&C7, anyone try MKC type instead of MKP?
attached simulation results as ZM advise (previously i was confused with those 2 timing options). am I correct to put I meter @2A? I am using talema encapsulated datasheet information on this simulation. it seems that CLC gives better result as graph shows
  • PSUD (CLC & LCRC).zip
right click on xformer - edit - click on button right of source res , fill in upper 4 fields
for effective internal resistance (impedance) of xformer , you need both voltages and Rdc of (both) primary and secondary
that's why I said that Ri of xformer looks too low
F1 is magic button in PSUD
