Dx Blame ST together Dx Super A
Heatsink
I found these Juan Small Size Aluminum Heat-Sink,
Gilded color, very beautiful.
For Package TO-220 Diodes, Transistors, Non-Inductive Resistors, LM78xx LM317 LM337 Regulator IC, etc.
M3 Screw Hole.
External Size: 15.2 x 25.4 x 23.4mm ( 0.6 x 1 x 0.92 inch).
Really nice
M3 Screw Hole.
Nice mister Eathguake I have those too they are just right in size 🙂 they use to have those in black and silver but all run out, the golden ones comes with the M3 screw that depends on the seller too but any way really nice :up:
Juan
DX SUPER A
Hi friends...yes i use the photographic method and i take special boards.I can give more details soon.
Best regards.
Let's go to explain this.
Firt of all ... special material.Bungard photoresist board.
Second step.A high contrast film (high contrast black printed areas).
This is the most critical and difficult to make.3 options available.
1 photographic film ....difficult
2 photocopies in transparent film ...easier ....but this method give good results if transparents are high quality .We must use color transparents and color photomachine but we must print in black&white.
3 The easier and most cheep method. We must print on non-extended rice paper with a laser printer.With this method black isn't so black but we have the way to resolve this.
We must spray this non-extented rice paper with White Spirit.Now it's time to dry it with a hair dryer.
Now we have a high contrast Black&Withe film.
It's time for exposure.
We need ultraviolet radiation.
The easy method is to use LEDS.
These are cheep on the Ebay.
Order some of them 200 or 400.
See photo for details.
Exposure time is critical.In my case withe rice paper is 4 minuites
After the exposure it's time for development.
We need 9 gram. of caustic soda in 1 litre water.
Development time isn't so critical.If exposure is right we must see photoresist go out about 3 or 4 seconds after .
Attention......all photoresist must go out,3 or 4 minuites is ok.
Now wash pcb with plenty of water.
The final step is pcb etching.
There are many materials .I use Ferric chloride from bangurd.
Tryk .Put pcb in 45 angle and wetting with chloride continuasly.
When all is ok wash with plenty of water.
Attention. You must use gloves and glasses.
Good luck,
