CFA Topology Audio Amplifiers
I am talking about DC stability. At HF the conditions are of course different
At DC, running all 4 input devices with the same Vce, Ic provides very good DC stability. If however the level shifter pair operate at higher Vce (no cascode), then they will still dissipate the same power and tend to largely cancel drift.
My two CFA designs are remarkably stable DC wise and that's a function of the excellent delta Vbe canceling effect of this topology. Note all 4 input devices are physically very close to each other.
Who, from the dark side, tried the nice idea of Bryston's quad quasi complemetary for the output stage ?
Nothing’s happening lately here. From the Dark Side another CFA amp this time with lateral MOSFET in the OPS, just to stir the pot. It uses TPC compensation but as Charry suggested a long time ago, instead to connect Miller cap to the VAS collector it’s connected to the OPS output. In this way THD20k goes down ten times. If used simple emitter follower drivers and distortion is twenty times worst.
I tried that with BJT triple but it’s to unstable, here with MOSFETs is much better, but there is one caveat. Look at Loop Gain picture, there is a peak at 25 MHz about, and it’s depend of the diamond predriver transistors used. Slower transistor lower peak and vice versa, and slower transistors lower LP and consequently increase distortion significantly. I simulated with BC5xx transistors here as it gives lowest distortion, but those transistors are with to low Vce.
Any suggestion how to remove that peak?
THD20k is 1.6 ppm at 50W/8ohm.
BR Damir
That's the reason of the comment of L.C. about diamonds. Tried to set a little cap in // with the feedback resistance ?
Your best result till now. I never try BJT for ops anymore.
I see Wahab and forr are conspicuous by there absence. 😀
Do I miss you ?
I asked you some questions and had no response.
I would not like to bother you by repeating them.
I very much dislike proofs of low distortion only based on simulations (their numbers now become excessive every and they bore me) or repetitive claims of better sound which won't resist one minute in blind tests. So recently, I did no see anything I had to comment.
I would not have made the following if you have not written your remark.
It is quite depressing that a french member refuses to read Douglas Self's book for the reasons he has given. Douglas is extremely easy to read and provides an amount of verified facts on amplification for which there is absolutely no equivalent. People having former certitudes have lost them when reading it.
I know Douglas's Electronics World articles on amplification since the first published in 1993 (at that time, I even knew his previous "Mosfet design"). It was not only before 2005 that he began to become really known and to have influence in France. I could have been very proud to know his works much before almost everybody in my country but in fact, I was very sad about the lack of curiosity of my french contemporaries.
Happily, this time is over. But not completely, as we see.
"I very much dislike proofs of low distortion only based on simulations (their numbers now become excessive every and they bore me) or repetitive claims of better sound which won't resist one minute in blind tests. So recently, I did no see anything I had to comment."
I am surprised at this forr since you were the one a few pages back telling us that CFA was no good and how you can get VFA THD down to -130 dB.
Did I ? All depends on what you, me, or third parties, mean by "good".
This is the oldest semantic problem since the human language exists.
I noticed too that we have come pretty much full circle. My trials have suggested that a combination approach seems to work best some lead lag + some form of miller. Either of the two pole miller approaches (TMC, TPC) seem the best for THD performance. Plain miller always seems to dissappoint.
Plain shunt I could never get to work very well in sims.
At least DTMC + lead lag works in reality and appears very stable even without an output inductor filter.
