Cute. . . it just keeps getting better.
I think I'm going to stop here. Time to do the real thing.
Besides ever time I post something it has a different op amp in it.
One of the interests i have since playing with a range of oscillators and distortion analyzers is to compare their results starting at -100dBr and below. Check for harmonic level accuracy and consistancy.
My Audio-Precision 2722 just showed up and I have to order some special interface cables to be compatible with the my new PC i7/WIN8 and software etc to get it going. I'll have some surplus distortion equipment to unload now.
Thx-RNMarsh
Can you take the lid off and tell us what's inside?
The lid is sealed by calibration stickers 😀
I know I was kind of joking but it would be nice.
Thx-RNMarsh
They've got some nice macros written in APBasic which you can download from Audio Precision : High Performance Audio Analyzer & Audio Test Instruments. The Impedance macro nulls the effect of cables complex Z.
It's probably time for AP to spend some time and money on a new GUI.
AS far as I have been able to determine, the ShibaSoku analyzer is a NIST/standards lab instrument compared to everything else..... including the A-Prec. It does not rely on a ADC IC as its basic instrument for measuring. The ShibaSoku design method/concept is made by all the other Japanses makers of distortion equipment for industry with added features and lower resolution for production and R&D use... such as National and Panasonic industrial test equipment.
The ShibaSoku is the size and weight of the A-P 2722 and is also packed full with circuitry..... however, the ShibaSoku does only one test -- harmonics. But it does it really, really well.
The A-P does a lot of other tests in the same space and this unit i have, A-P told me it has a $4720 option in it - A Dolby generator of some sort. ??
Between the 2 analyzers, i should be able to fairly well characterize the 99 percenters as to accuracy below -90-100dB and what harmonic data changes happen with level etc.
Thx-RNMarsh
Thx-RNMarsh
Ordered all odds-n-ends plus another option -- the IMD option (can you say $$)
This is a budget buster.... but will last me for another 10 years like the SYS One did. By then i will have caught up. Maybe.
Thx-RNMarsh
Thx-RNMarsh
Thx-RNMarsh
My feelings as well. For day to day work with audio on a bench something like the Boonton or HP gets results very fast and is great for troubleshooting. The AP is wonderful for creating charts and graphs with automation and production line testing. The Shibasoku is more like a primary calibration standard. Its really good at what it does. Richard's newer one has the improved filters so it can be used with DAC's and really determine the performance floor. But its really a research instrument and assault on the state of the art of pure analog design.
I don't think it will be on the for sale list from what he wrote. . .
Actually, yes..... I will have to open it up to install the new option kit (IMD) on order. Then, I can take pictures for everyone.
-RM
Should probably start an SYS2722 thread -- I know a couple folks in Hong Kong using them. You'll probably want to fiddle with the detector speed settings.
Actually an AP thread would be very helpful. Are the scripts etc. for the System One compatible with the newer analyzers?
Ap thread
Here you go guys. A dedicated thread for Audio Precision.
http://www.diyaudio.com/forums/equi...precision-ap-analyser-series.html#post3582673
Does that unit have GPIB? My older unit use a different circuit architecture. I posted an interior some time ago. I believe the AG16 is the same as the AG15.
Need to figure out the GPIB command set for these.
I would hope that with the 15/16 connected to the 725 via GPIB that when the oscillator level or freq were changed, the 725 analyzer would respond accordingly. OR is the GPIB there to interface with a PC to control and gather data and Not be connected directly to each other. ??
And, then we have APIB. Why didnt A-P stay with GPIB? Is the APIB a stripped down GPIB or what? I guess the APIB/GPIB was put there for a factory automated test station/system and be a way to connect to other brands (TEK, HP, etc). For low volume use, the APIB/hardware/software doesnt seem worth the effort to use it.
THx-RNMarsh
THx-RNMarsh
The GPIB allows a PC to control and run a test sequence and collect data. The analyzer will auto tune and level adjust to its input. With the GPIB you can plot distortion vs level or frequency or frequency response.
The AP only works this way.
It looks as though the Shibasoku uses an analog multiplier as the AGC element. Both the AG15 state variable oscillator and the 590AR Wein bridge seem to use the MC1495L analog multiplier http://www.onsemi.com/pub_link/Collateral/MC1495-D.PDF . The part is socketed so selection is probably a key part of the process. They get exceptional performance with pretty conventional parts.
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
